Old 05-17-2016, 08:11 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
PM sent.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-18-2016, 10:59 PM   #16
Webster , Texas
New to forum
I have a 2014.5 interstate
I just replaced all batteries including the starter. All charged up and the starter battery is already dead within one day? Had to use the battery assist button to start the engine. Do I have a setting wrong?
Also I have had battery issues since I bought this unit. So would love to know how you did this upgrade as well!! Thought new batteries would do the trick.
thank you!!!
Musthaveit is offline   Reply With Quote
Old 05-18-2016, 11:14 PM   #17
lewster's Avatar
First shot is a 300 amp/hour lithium with a Magnum MS-2012 and 400 watts of solar. Second shot is the 800 amp/hour lithium with a Magnum MSH-3012H hybrid inverter/charger.
The positioning is under the rear lounge of a couple of Interstate Grand Tour coaches.
Old 05-19-2016, 04:55 AM   #18
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Are you sure you replaced the starting battery? The one under the hood isn't the starting battery— the starting battery is under the driver's footwell.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-19-2016, 08:59 AM   #19
Webster , Texas
yes the battery under the foot well of the drivers seat. They had my rig for about a year on the lot before I bought it. I had battery issues from the beginning. After sitting for a few months this year, I plugged into shore power for 2 weeks and thought that would charge all batteries. But all batteries were dead and toast. So just replaced them. Replacing the starter battery also meant going to the MB dealer as the check engine light came on as well as bells that would not stop dinging. Side note, I bought the replacement batteries from them as well but installed them myself. They fixed that and then the next day, the starter battery was dead. So thought our small road trip to the beach would charge it. It did but once I turned engine off and just let the generator run, it ran down again.
Another side note is my radio will always stay on when everything else is off. I have to turn it off to stay off. Always thought that was strange.
I am new to RV so I must be doing something wrong here. The dealer here is not much help so found this forum and so far have learned more in a few hours of reading this than days at the dealer, so Thank You in advance!!!
Old 05-19-2016, 09:02 AM   #20
Webster , Texas
This looks awesome! Thank you for posting!
Old 05-19-2016, 10:08 AM   #21
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The original batteries were definitely damaged by sitting so long without a charge. There is something wrong with your system if the new starter battery was dead in one day. You will need to to get it checked for unwanted battery drains.
Regarding the radio it has two modes the way it was wired by Airstream. If the house battery disconnect is ON the radio must be turned off manually. If the house battery disconnect is OFF the radio will shut off when the vehicle key is turned off.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-21-2016, 09:27 AM   #22
2016 Interstate Lounge Ext
Heathrow , Florida
Anybody have any idea what the new Fusion stereo going into the 2017 AI is all about? Can't be any worse than the Kenwood but I can find no info on the unit.
Harleydeal is offline   Reply With Quote
Old 05-21-2016, 03:56 PM   #23
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
This appears to be Fusion's RV unit:
http://www.fusionentertainment.com/c...units/rv-cd800
Old 02-28-2017, 05:02 PM   #24
2015 Interstate Coach
MEDFORD , New Jersey
Lew,
How can i PM you to get contact info. going to be in Bonita Springs end of March
RICKBETTY is offline   Reply With Quote
Wish List Mick33 Off Topic Forum 4 11-27-2013 09:22 AM
Interstate wish list UKDUDE Sprinter and B-van Forum 27 07-26-2013 02:10 PM
Wish List for Airstream 'Carport' Frank&Mike Winterizing, Storage, Carports & Covers 28 05-01-2013 07:47 PM
Wish AND FIX UP list for MH PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 35 07-25-2009 10:49 AM
Dear Santa, here is my wish list..... Janet H Off Topic Forum 30 12-17-2004 12:54 PM
