10-13-2009, 06:09 PM
1979 24' Airstream Excella 24
Adams
, Tennessee
Wiper Parts
Hello all I'm looking for sources for repair parts for the wiper systems
on a late 70's Airstream Classic, I have a 79 24 ft Excella P-30 chassis
the wiper motors are good but I am searching for info on the linkage
bushings and link studs that operate the wiper blade from the motor
I would like to know if anyone has rebuilt this linkage system and has
a source for parts. I will check back on this post to see if anyone can help
Thanks a bunch if you can help would love to hear from you
Bfrank
Frank & Lisa Sullivan
10-16-2009, 12:09 PM
1984 28' Funeral Coach
Sumter
, South Carolina
Millsupply.com and the step van catalog
Glen Coombe  AIR #8416
Golf Professional Sales Rolling Showroom & PuttLab
"I'm not an expert. But I did sleep in an Airstream last night."
10-16-2009, 04:36 PM
1985 34.5' Airstream 345
Leesburg
, Georgia
04-08-2011, 06:22 PM
1989 34.5' Airstream 345
Jamestown
, Kentucky
Originally Posted by elbundi
Pictures ??? Ha Ha, I am working on Mine also. eeegads
04-09-2011, 11:37 AM
Leesburg
, Georgia
Alas, those photos must've succumbed to computer gremlins!
While you have the wiper motor out make sure to get the correct angle on the drive arm ! When in park mode my drivers side is not at its lowest point and stops about 10 degrees up from where it should! I can trick the wiper to stop at the bottom by turning the switch on and off really quickly. This is liveable as I don't want to take it out again unless necessary.
Another thing to look out for which I'm not sure how it happened, but when the wiper is on at normal speed the passenger side is on fast, and conversely when the drivers side is on fast the passenger side is normal.  again entirely liveable.
Good luck. Using a couple of swivel sockets help.
04-11-2011, 05:20 PM
Jamestown
, Kentucky
what wiper blades does everyone use ?
I thought I saw someone post a Part Number.
do you use 18 or 20 inch Blades ?
Thank You
John
04-11-2011, 05:38 PM
1993 36' Land Yacht
jackson
, Tennessee
there is only one truly dependable supplier. they were referred to me by airstream. service...magnificent. inventory...gigantic. go to rome truck parts in rome, ga. overnight delivery. remarkable.
04-13-2011, 07:55 PM
Jamestown
, Kentucky
Thank You
John
I ended up with
ANCO wipers, Heavy Duty 52-20
they came from my Local auto parts dealer.
exactly the same as the units I replaced.
Listed in the Parts book as Airstream, Heavy Duty 20 inch Units
04-27-2011, 09:23 PM
1982 31' Airstream 310
Columbia
, Tennessee
Got my new wiper blades
Thanks for the info on the wiper blade part number. I went to my O'Reilly Parts store, and they had them in stock, and whats better they cost under 18 buck for both of the complete wiper blades. They look to be Stainless Steel, and had to use the spacer supplied. These also come with the screw and new ny-lock nut. I have Stainless lock nuts, so did not use their nuts. The screws are SS.
When not in your Airstream,
Check out our travel site Woodexcursions-dot-com
for your vacation and business needs.
Chris & Brenda
AIR Member 12654
1982 310 Motor Home
Toad 98 Saturn SL2
More on our 310
05-01-2011, 09:58 PM
1982 28' Airstream 280
Redwood City
Thanks for the info on the wiper blades. Mine were shot and I didn't know what I was going to do to find replacements. I saw the post that Anco 52-20 was the replacement. I stopped at the local Kragons/orielly store and asked if they had such a blade. She looked on the computer and said they should have two. It took her a while to find them in back. I installed them today and yes they are direct replacements for what was on the MH. Thanks everyone!
08-10-2011, 02:15 PM
Grain Valley
, Missouri
I was getting nervous about the wipers on my 1984 Holiday Rambler because I have to have a state inspection and the wipers are shot. After reading this thread, I went to O'Reilly's and ordered the 52-20. Got them today and they are an exact replacement for what is on there. Thanks you for the info. I thought I was going to have to special order them from some high dollar bus or truck company. They were $15.98 for the pair. Thanks again.
Dan
12-03-2011, 06:57 PM
1976 28' Argosy 28
Dallas
I need to paint my wiper arms. Anyone take them off? Do I need a puller?
12-03-2011, 07:12 PM
Redwood City
I recently took mine off on my '82 in order to reposition them...they were too low. I took the nut and washer off, took the pressure off the spring (with hands only) and they lifted right off with a little tap on the stud with a hammer. Make sure you don't damage the threads. Try a little liquid wrench first if they won't budge, let it set awhile, then tap stud with hammer. Of course if you have a puller all the better, but I didn't need one.
12-04-2011, 01:25 AM
1976 28' Argosy 28
Dallas
Which spring? Does it matter? I did everything else you listed. Used a rubber mallett.
| Thread Tools |
| Display Modes |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Wiper Blades
breeze |
General Motorhome Topics |
3 |
03-04-2009 12:39 PM |
345 windshield wiper parts
raveson |
Classic Motorhomes |
5 |
09-27-2007 08:04 PM |
Rear Wiper...
canny_banjo_man |
Mechanics Corner - Engines, Transmission & More... |
0 |
05-27-2006 12:17 PM |
Need some help with wiper problem
guy99 |
9 |
01-31-2006 09:32 AM |
Wiper Woes
smily |
5 |
02-13-2004 06:37 PM |
