Old 08-15-2003, 05:24 AM   #1
Window guides
Just bought new positioning guides at the factory and now am trying to figure out how to replace them. Has anyone done this on a '71 Safari? Drilling out the pop rivets isn't any problem. How do you remove the split washer that holds the pin that pivots in the window bracket? The arm doesn't seem to be removable at the other end, even with the interior handle removed.
Thanks for any help or advice.
Dan
Dbraw is offline   Reply With Quote
Old 08-15-2003, 07:03 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Dan,
You first must remove the screen with the window closed. The edns of the lift arms come off with a allen wrench. Then after you drill out the rivets the arm can be pulled out of the plastic step retainer. If the old ones are bad you can just cut the retainer, but remember to put the arms back in before you begin to rivet.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Window latch adjustment question! Kistler Windows & Screens 4 08-30-2003 01:10 PM
Report of window replacement in 1977 Minuet 6.0 kenny All Argosy Trailers 2 08-27-2003 07:11 AM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 04:25 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
