Old 07-03-2015, 03:50 PM   #1
Where to find MH A/C Parts?
1999 30' Land Yacht. Our A/C has stopped working and apparently needs some new switches (high and low pressure). But unable to find any specs giving the nomenclature of these switches. Wish that I could narrow this description down, but . . . . .Any leads on this, or supply source(s) would be helpful.
Mike
comprose is offline   Reply With Quote
Old 07-03-2015, 04:31 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
That would probably be a Spartan chassis. Most of the workings are direct from GM. You should be able to remove the switches, and search for replacements using the production numbers on them.
Old 07-03-2015, 05:12 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Any "bus" AC joint worth their salt can help. I have locals who work on all sorts of "undocumented" AC systems, with near perfect results.
Then again, this is Texas.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-04-2015, 05:03 AM   #4
1995 36' Classic 36
Ludington , Michigan
http://www.acmeairparts.com/
http://www.acmeairparts.com/rvacheaterparts.php
Kota is offline   Reply With Quote
Old 07-04-2015, 03:04 PM   #5
Many thanks. I'm hopeful that this, plus some schematics I found in the Airstream owner's manual as well as the Acme resource, get's me back on the road with a functioning AC.
Mike
Old 07-04-2015, 03:37 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Mike
Please post results, especially source and parts that fixed, rv repair shop fixed mine a couple of years ago by replacing compressor, it worked but said it would never match a car a/c due to volume needed. When I suggested a larger output unit they scoffed and said had to use standard. It is having a problem again and the parts they didn't replace is probably the cause. the warranty period is over and shop changed owners.
Old 07-04-2015, 03:54 PM   #7
Will do on this thread, Dave. Hopefully will know something by the end of this week.
Old 07-04-2015, 07:16 PM   #8
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
ac
It is not a bus or a Spartan it is a workhorse p32 by chevy. you can buy the ac parts at napa. I just replaced my compressor,switches & filter dryer & got it all there. Gary
garypk is offline   Reply With Quote
Old 07-04-2015, 07:39 PM   #9
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Your dash air on any motorhome will only be comfortable if you can control to some extent, the area being cooled.
Some type of barrier curtain is a must to be comfortable on those long drives into the afternoon sun.
The system does not have to be complicated, but it should go to the ceiling, and should overlap at your entrance so that it slows the air exchange with the main body of the motorhome.
I run with the bylevel Air, on MAX. but the fan speed set to slow, once the cabin is initially cooled down. It is quiet, comfortable, and the barrier curtains are only pulled back all the way when the TV is to be watched.
http://www.airforums.com/forums/f313...ml#post1608622
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
1982 Motorhome classic parts find. RichardT Classic Motorhomes 1 03-19-2006 07:05 AM
Where do I find these parts? Becky B. General Repair Forum 5 09-25-2005 12:11 PM
What are some of the hard to find parts? (are bins?) tiniree General Interior Topics 5 05-01-2003 08:45 PM
