Old 06-30-2003, 10:49 AM   #1
When should the rear airbags be replaced?
Any thoughts when the rear air bags should be replaced?
1988 345 with 66,000 miles. They look brittle where they make the 180 degree turn up. At the moment I am trouble shooting the system as they quit inflating this week.
AccessMaster is offline   Reply With Quote
Old 06-30-2003, 10:53 AM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
when they dont hold air would be the time i would replace. or if the look so bad that they are close to poping. sounds like it is time. lol
al
wb13798 is offline   Reply With Quote
Old 06-30-2003, 01:17 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I am in the process of needing to do the same thing. My understanding is the Airbags are still being made. The only hurdle is the fact that the Airbags are currrently being produced, there are none in stock nationwide. If I can I will get the numbers posted so you can order new ones, later today.
If you need any of the part numbers let me know, I have a copy of the original book.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-30-2003, 02:37 PM   #4
I sure would appreciate any information on which ones to get and where to get them. Can you suggest where I can get the instructions on doing the change out. Are there any tricks or problems I should know about. I hate learning everything the hard way.
Old 06-30-2003, 05:50 PM   #5
wb13798's Avatar
2004 28' Classic
if my memory hasnt failed . on the top of the bags is two nuts and the air line and on the bottom is a long bolt that has to be removed. and they should slide out . of course you need to jack and block the frame up so it dont fall on you. lol
al
Old 06-30-2003, 05:57 PM   #6
wb13798's Avatar
2004 28' Classic
forgot to mention take one out and take it to fleet pride or any heavy duty truck parts center. they are made by firestone and the part number is on the bag. fleet pride has the inventory for all their stores on line and if they have the part in tim buck tu they ship to the store that request it or they can order from firestone. if you buy from a airstream dealer you might plan to part with some extra bucks. lol
al
Old 07-01-2003, 10:16 AM   #7
Edie's Avatar
Dallas , Texas
The 1978 Argosy 28 MH we just purchased came with all original documentation. Included is the booklet from Firestone with all the part numbers.
I called Firestone Industrial Products at 800-888-0650. They confirmed that my part number is correct for a 1977 P30 chassis. Additionally, they gave me an alternate part number for the same item that might be available through heavy duty truck support.
The part numbers are (original part number listed first):
W21-760-5405
W01-358-5405
Good Luck!
Edie
Edie is offline   Reply With Quote
Old 07-01-2003, 11:46 AM   #8
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Here is the skinny.
The bags will not be available from Firestone until 7/15/03 or later. They are in a production run now, and that is a estimate on a ship date.
Cost is 131.41 each from Fleetpride.
There is a bag that could be used if you were in a jam, but it has a 2 inch shorter overall height. It is made by Goodyear and is Fleetpride # 5328. I would not reccomend it as a permenant replacement due to the fact that it will more than likely have to be at 100% inflation to get the coach near to normal ride height. But is you are in a jam something is better than nothing.
Fleet Pride home page
There is a store locator link with all of the stores nationwide and 800 #s to call each one.
Brett G
Old 07-01-2003, 01:35 PM   #9
Thanks guys for all your input.
I can not figure out why the bags did not inflate Saturday. After connecting my own air compressor to the system and removing the coach compressor the system pumped up just fine. When I put the coach air compressor back on line the pressure continued to hold up. Maybe a relief valve hung up somewhere. The bags looked good when they were inflated vs deflated. Guess I will wait a while longer before replacing them.
Old 07-01-2003, 06:24 PM   #10
wb13798's Avatar
2004 28' Classic
you probably had a stuck check valve. dont know why they wouldn t pump us unless your compressor is shot. would think it would pump up and then leak down . or the leveling valve was stuck open would more likeliy the problem.lol
al
Old 07-02-2003, 07:26 AM   #11
I did have one side of the coach jacked up with the tires off the ground in the rear. Maybe that caused the leveling valve to have an issue for awhile. Where is that valve by the way?
My system had approx 80 pounds in it but the dash indicator was on the border between red and green. Where is the 9 inch measurement supposed to be taken to determine if the bags are at proper height?
Old 07-02-2003, 09:23 AM   #12
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The leveling valves are mounted either on the frame behind the air bags, or you may only have one in the rear center. Depends on model year. Just follow the funny rod that is behind the bags to the valve on the frame.
If you had the rear tire off the ground, but the jacking point was the frame, the hanging axle would cause the valve to dump air. I do not know if it is necessary to have the key on for the dump valve to open or not.
I have been told the actual inch measurement is at the bottom of the rear bumper while on level ground. Some years were different, so the 9 inches may be right, or could be wrong.
Brett G
Old 07-02-2003, 09:33 AM   #13
roskoe's Avatar
just a quick question. i have a 76 argosy should u have an air pump on the unit? i have to air valves on the back bumper. should thier be any for the front. if so where?
thanks
matt
roskoe is offline   Reply With Quote
Old 07-02-2003, 09:35 AM   #14
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Matt,
The 76 model did not come with factory air bags at all. Many owners add the front inner coil types and some will add "helper" ones in the rear to smooth out the ride. If you have fittings in the rear that would make me think you have rear aftermarket ones. If they were installed up front sometimes they put a fitting in the grill. Others just have the valve sticking out of the bottom of the front coil spring.
Brett G
Rear airbags on '87 345 - any tips or tricks moeriv Classic Motorhomes 11 06-25-2019 07:13 AM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
1990 345 Motor Home Rear Airbags Howard Lefkowitz Classic Motorhomes 5 05-11-2007 09:59 AM
To replace rear airbags on Classic 350 w/Tag Axle boones Airstream Motorhome Forums 0 05-06-2006 03:29 PM
Rear airbags needed for my 1988 345 motorhome Mr. D Mechanics Corner - Engines, Transmission & More... 2 04-03-2006 03:05 PM
