Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 11-24-2003, 05:49 PM   #1
josephhh's Avatar
1979 24' Airstream Excella 24
Macon , Georgia
What's the Deal with 2-Speed Rear Ends?
I am thinking it would be cool to have a 2 speed overdrive rear end installed. Seems like it would lower RPMs and increase gas mileage. I have a 24 footer and I think I would have the power available to support the gear ratio.
Anybody smart on this topic?
Joe
josephhh is offline   Reply With Quote
Old 11-24-2003, 05:53 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
what about the Gear Vendors over and under drive? Sounds like it would accomplish what you are wanting, many Mh's use it.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-24-2003, 05:55 PM   #3
josephhh's Avatar
Macon , Georgia
Thanks, do you know where can I see info on it?
Old 11-24-2003, 06:00 PM   #4
josephhh's Avatar
Macon , Georgia
Found the Website
OK I found the Gear Vendor's website. The gizmo looks like it is a transmission replacement with overdrive. Looks EXPENSIVE. I was envisioning a differential replacement. But what do I know....
Old 11-24-2003, 07:00 PM   #5
Retired.
. , At Large
Re: Found the Website
It IS expensive. I put one on a tour bus a few months ago. It helped fuel consumption, and engine wear, but cost almost $1800.00, but a two-speed rear end is much more. Even a used rear end is a ton of money, and then you have to pay to make it fit.
What transmission do you have in your rig now? And what ratio rear end do you have now? And, what engine? You may just be able to change gears in your current axle, without having to resort to major, expensive surgery.
Old 11-24-2003, 07:04 PM   #6
josephhh's Avatar
Macon , Georgia
Good info.
I'll check on the data and get back to you...
Looking in the manual now....
Old 11-24-2003, 07:44 PM   #7
josephhh's Avatar
Macon , Georgia
I reckon I will have to climb under there and look!
Can't see from the service manual. It says hydromatic 400 and a 101/2" rear end gear. 454 engine. All stock (I think). Only 42K miles on the rig. I'm out of town early in the AM till after Turkey day. I'll look up under it when I return.
Thanks for the help.
joe
1970 GT ends today in Austin TX, fair deal? streamahead Airstreams on eBay 0 09-14-2010 11:29 AM
1965 Tradewind deal or no deal soldiermedic Trailer Values 32 03-05-2007 04:54 PM
68 Safari...Deal or No Deal? soldiermedic Trailer Values 15 10-29-2006 09:54 AM
Trying to decide - Deal or No Deal baldwicm Wheel Wells 19 04-06-2006 07:39 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
