Water heater replacement wiring issue
I am replacing my ATwood GE-9 EXT 6 Gallon WaterHeater in my 2014 Airstream onyx international19'. Due to operator error and not properly winterizing the WaterHeater tank. I had a whole the size of a baseball probably from water freezing in the tank. I removed the old tank and with a brand new one of the same model. When I re-wired the new tank I must have done it wrong because I have everything connected but no light on the switch and no spark of any kind. Any suggestions or pictures of how they are wired? I took the old one out last weekend thinking it would save time this weekend for the install. I should have labeled everything. I think I will change the fuses just to be sure that isn't the issue.
