MYRVADVANTAGE,
If your '94 Golf III is the same as a 93-02 Cabrio VW, then Blue OX part #3818 is the baseplate for you. If Blue OX can't help you
www.aemfg.com, then maybe Roadmaster can.
Most any stick shift can be towed. Whether they are 4X4( place in transfer case neutral, no miles added) or 2X4 ( will add miles, unless you use some sort of driveline disconnect). ALL-WHEEL drives may require a tranny lube pump. More manufacturers won't own up to the fact that one of their products is towable, since they don't want to warranty it.
We bought an '03 Beetle stick TDI to tow, but didn't since a schnauzer and husky wouldn't fit in Bug's backseat, even folded down. So, we tow something a little more accommodating for dogs, bikes, gensets, lawn chairs, grey tank, etc.
If you go to
www.fmca.com and search out their dinghy guide, its list many toweds.
