Old 02-27-2019, 09:47 PM   #1
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
Turn signals not working?
Hazards works, brake lights work, but no love from my turn signals. Here is what I know:
- the flasher in the fuse box is not getting power.
- the grey wire in the going into the bottom left green connector on the fuse panel is not getting power
- the grey wire leads up to the steering column.
- turn signals were working earlier today, I was doing some work behind the dash and installed a new switch bank to the right of the steering column. Once I buttoned everything back up, turn signals were not working.
- I have checked all the fuses in the fuse panel and they all appear good.
Does anyone know exactly which fuse is for the signal lights?
Any other ideas?
Michael
Note: not sure why both pics are upside down, they are right side up on my phone.
ID:	334601   Click image for larger version
Michael_Wild is offline   Reply With Quote
Old 02-27-2019, 11:18 PM   #2
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
What is your tow vehicle? I had the same issue in my 2011 F250 and discovered there is a fuse for the trailer turn signals.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 02-28-2019, 05:25 AM   #3
I believe the subject under discussion is a 1984 310 Motorhome, not a trailer tow vehicle.
What you're looking for is the GM chassis wiring diagrams for the 310. If you can't find wiring diagrams I have copies of the chassis diagrams at home that I can post later this evening or tomorrow.
Old 02-28-2019, 06:38 AM   #4
Michael,
If you follow this link to the GM chassis wiring diagrams and then go to Nick's post #93 you'll find links to help troubleshoot your fuse block problem.
Old 02-28-2019, 09:15 AM   #5
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Thanks Brad, I will check it out.
Old 03-06-2019, 12:17 PM   #6
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Don't be stupid, stupid
This problem was total user error on my part. Turns out in the process of testing the fuse box, I removed the turn signal fuse and neglected to replace it. Here is a diagram of the fuse box, a lot of the writing on mine is worn off so I didn't see the "Turn B U" label. Here is a pic I found on the internet in case anyone else has the same problem:
Name:	1984 Airstream 310 Motorhome-Fuse Block.jpg
Michael Wild
www.theWildsLife.com
Brake lights, turn signals, reverse lights not working! HELP! blogworthy Argosy Motorhomes 6 04-16-2018 06:21 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Stop Sights, Turn Signals Shiny metal Lights - Interior & Exterior 5 09-14-2009 10:20 AM
turn signals backwards from truck mcair Lights - Interior & Exterior 7 06-02-2009 05:31 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
