Old 04-27-2015, 07:46 PM   #1
Brewster , Massachusetts
towing with a 280 diesel coach
Hi,
I have a 28' 280 turbo diesel coach and have never towed with it before. I recently bought a road master falcon 2 tow bar and stealth braking system for towing my 2009 Honda CRV. It weighs about 4500 lbs. Is this car too heavy for this coach to tow? Any help would be appreciated.
Doug
Doug S is offline   Reply With Quote
Old 05-06-2015, 10:24 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Probably too heavy, check all limits, AS started at about 2k and has changed limit over the years, owners have changed them even more by beefing up the frame, adding higher weight capacity hitch.
I liked the CRV but being heavier than the Ford Ranger pu opted to get the Honda Fit at 2.5k, still pull the pu when we are on flatland, haven't figured out how to carry kayak and bikes with Fit.
Old 06-17-2015, 05:24 PM   #3
Santa Cruz , California
Images: 12
Too heavy
Yes, 4500 pounds is too heavy, unless you stay slow and on flat roads. The factory limit is 2000 pounds. We tow a 2200 pound Tracker with our 310 turbo diesel. It's fine except on hills, when it gets slow but manageable. Be sure you have sufficient cooling (big radiator fan, transmission oil cooler with fan) and don't push it to go fast.
dljosephson is offline   Reply With Quote
Old 06-17-2015, 06:43 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Think about rebuilding your hitch structure. It's pretty light weight and not attached to the frame in a manner to tow that kind of weight.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-17-2015, 08:01 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
You have curb weight mixed up with gross vehicle weight as the curb weight of your CRV is 3389 lbs, not 4560 lbs which is your max gross weight. See link below.
Used 2009 Honda CR-V Features & Specs | Edmunds
Even at 3389 lbs it would be advisable to beef up the hitch significantly.
Cheers
Tony
Old 06-17-2015, 08:32 PM   #6
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I understand some of the issue is simply power/weight ratio, but could using a Hitch-Helper to carry the load help? Really they are just an update of the old slimp dolly idea to carry and distribute load, but must be novel as the company have various patents around their design.
I have been looking at them as a hitch hauler for our motorcycle, but they are quite popular with the marine haulers towing weights way over that of their tow vehicles on their own, there is even an old thread on using them (http://www.airforums.com/forums/f464...lly-87055.html) with links to the Hitch-Helper and another product called the TrailerToad.
martin300662 is online now   Reply With Quote
Old 06-18-2015, 12:01 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Aftermarket roof bars on the Fit for the kayak— I use Thule Whispbars (Whispbar | Car Roof Racks, Bike Racks, Ski Racks, Kayak Racks) on my Fit for carrying a kayak— and a hatchback-mounted bile rack on the Fit for carrying bikes. Haven't used them while towing (yet) and not both at the same time, either. But even if it only allows you to carry a kayak OR bikes while towing, that's at least half a solution.
Cats and ultraleather Airstream upholstery don't mix!
Old 06-22-2015, 06:19 AM   #8
Thanks all for your input. Since I first posted my question, we traveled with the CRV from MA. To the Smokey Mountains. I did find that the coach over hated some going up some of the mountains in th Hudson Rver Valley and in the Blue Ridge, especially when it got warm out side. I have just leased A Smart car to tow. Hope that works. Thanks again. Doug S
Old 06-22-2015, 02:33 PM   #9
My smart tows well and it is fun to drive.
Cheers, Dan
Airstream 280 Turbo Diesel Motor Home eBay Watch Airstreams on eBay 0 03-01-2009 08:20 PM
Normal "RPM" for 280 Diesel? brewer00 General Motorhome Topics 2 05-05-2008 12:26 AM
Considering a 280 Diesel? Any thoughts? altemplet Classic Motorhomes 12 03-31-2008 04:36 PM
280 Turbo Diesel hill4th@gvtc General Motorhome Topics 0 09-20-2006 12:15 PM
