Old 11-04-2013, 10:03 PM   #71
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There is much $ worth of old Sokol vee dub there.
A Thing, a Bug, and a Transporter...
I'm impressed!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-04-2013, 10:04 PM   #72
m.hony's Avatar
2013 30' Classic
Old skool...
Spell check is stoopid!
TAC #MS-10
Airforums #70955
Old 01-18-2014, 05:26 AM   #73
Rocket Man Ken
RocketManKen's Avatar
2001 39' Land Yacht XL 330 hp w/slide
Brookville , Ohio
The beauty of air cooled beetle is only 8 moving parts. If we all try hard enough to find negatives... I had a 67 Beetle drove heck out of it, probably abused abit. In 67 most cars had lousy brakes, heaters, driveability issues. We are fortunately very spoiled with computer fuel injection and all dependability today. I don't know anyone that keeps a pipe in their car to wrap on the starter motor occasionally.
Back in the day it was normal to pump throttle 3 times, hold steering wheel slightly left, turn key. That is unless you were parked in street in front of house then it was 4 pumps or below 30 degrees. But if it rained the night before....
Loved beetle, loved my 83 Rabbit GTI.
'Of course that's just my opinion, I could be wrong'.
RocketManKen is offline   Reply With Quote
Old 01-18-2014, 07:09 AM   #74
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Gang,
Just a comment from a friend of mine from years ago. His Dad was towing a manual transmission Samurai IIRC and had a few boxes of stuff in it, just using the storage space. All was well until he braked pretty hard and one of the boxes knocked the stick and put it into gear. The rig kept going windmilling the Samurai engine for mile after mile (sorry, don't know what gear it was in) finally damaging the engine somehow.
Just a comment, but I just relaying someone else's story.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-18-2014, 08:20 AM   #75
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by GCinSC2 View Post
Gang,
Gary
Seems like if it managed to get in reverse, while being towed forward it would turn the engine (and thus the oil pump) backwards and not circulate oil in the engine. That would likely do some damage in short order. A forward gear should work out ok, though if it were a low one the engine would make quite an air compressor. That would probably eventually hurt it at highway speeds.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 01-18-2014, 09:48 AM   #76
1974 Argosy 20
Kooskia , Idaho
A motorhome towing a small car came past my place one day (30 mph road). I could see the smoke coming from the towed. I ran down and flagged the guy down to stop, as he had a fire.
Turned out to be a very old man driving the motorhome, and it was obvious to me that he should not have been out on the road. He was vague, and quite confused. But what had happened was that he left the towed in gear, and had pulled it 5 miles from the campground using brute force of the motorhome engine. The engine in the towed was turning over and the compression and friction was heating the water in the water jacket. What looked like smoke was actually steam from the towed engine.
And I don't know what damage he did, or the rest of the story.
Old 01-21-2014, 07:19 PM   #77
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Towing a VW
No you don' need a brake buddy, as you probably already know. They flat tow beautifully with a cheap tow bar. Hint: Hook a strechable bungee cord under the seat and the the lowest point of the steering wheel so it returns to straight after a turn.
We've been towing this 66 VW for24 years. It's still a six volt car and I had to make a light bar that bolts onto the rear license plate frame. Then I ran a wire through the floor pan rail from front to bact that plugs into the light bar. It's easily removabe, as sis the tow bar. Great arrangement and I think about 20,000,000 VW owners have shared their VW stories whenever we stop.
The car is called the "Road Bug".
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 01-22-2014, 04:20 PM   #78
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I towed a 69 Karmann Ghia for years. Nice and light, towed easily and didn't need a brake buddy. Only down side was if you needed heat in cold climate or AC in a hot climate.
- - Mike
Old 04-19-2015, 07:26 PM   #79
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
April 2015 Update!
Well I thought I'd track back and update an old post with the latest information. We actually towed the Beetle today and it towed great. Here are some pictures.
ID:	236631   Click image for larger version
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 04-19-2015, 07:30 PM   #80
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Very nice Fred, how did it go? We are looking at toad options for ours (assuming it ever gets finished!) but not sure the little 350 has got enough punch to pull a small convertible.
martin300662 is offline   Reply With Quote
Old 04-22-2015, 07:52 PM   #81
ViewRVs's Avatar
1977 20' Argosy 20
Martin,
It towed fabulous! I hardly knew it was back there! Only the little bit of orange roof in my rear view mirror gave it away. It tracked right along. I think it accelerated a little more slowly but I never really stomped on the gas either. With the 454, pressing down hard on the pedal can consume a gallon of gas! I did not notice much difference in braking either.
The biggest disadvantage, other than the face that the car is 41 years old, is that the two bar requires you to get on the ground and reach under to put in the pins. It can require a towel since you can get a little dirty. The other challenge is what to do with the tow bar when not connected (home and campsite). The price is right though! $110 as opposed to $400 tow hooks and a $1,500 tow bar assembly!
Fred H.
