Old 07-20-2012, 05:26 PM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Steamguy: A hot-running air-cooled engine that has to work relatively hard to do its job is the ideal case for high-octane fuel. It's people who run it in low-compression V8s that almost never generate half their rated horsepower who are wasting money with it.
— David
Old 07-22-2012, 02:50 AM   #30
Phoenix , Arizona
I have owned many beetles over the years and they are fairly reliable for being as crude as they were.
As far as towing, there was a trailer design that consited of rectangular tube (approx 2" x 4") and it was shaped like a "T". The leg of the "T" was the tongue and behind the cross of the "T" was an area for the rear tires to set it. The front side of the cross of the "T" was the ramps. The cross of the "T" was actually the axle with no suspension. All you had to do was back up over the long part of the "T" and once the rear tires went up the ramp and backed over the cross part of the "T" (the axle) the tongue would slam into the bottom of the car (I suggest a rubber pad in this area). You had to pick up the tongue (heavy but not really as bad as you would think) and put it onto the tow vehicle. It would be easy to put surge brakes on a simple trailer like this. The reason it didn't need suspension is because the car's rear suspension strapped to the rear of the trailer. It would also be easy to make one with a rubber torsion suspension but you would have to be careful where the balance point was or you wouldn't be able to lift the tongue up.
M2HB is offline   Reply With Quote
Old 07-22-2012, 04:45 PM   #31
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
That 70's Show!
Here is a preview of your new rig! Literally!
1979 Argosy 20'
1974 VW Beetle
Name:	2012-07-22 Argosy Beetle.JPG
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 07-22-2012, 08:47 PM   #32
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
As I'm fighting off a summer cold, und das bier is taking effect, please indulge me a bit of reminiscing.
I've been professionally involved with the service of the “Nazi Boxes”, VW, Porsche, Audi, BMW, for 40 years.
Some have questioned the reliability of VWs in that era. Time has a way of blurring the historical record.
Anyone remember the Bugs contemporaries? Chevy Vega, Ford Pinto, Triumph, MG, Opel, and (IMHO Worst ) Fiat Spyder? These engineering marvels populated VW dealership's used car lots until the late '70s.
OK, I will admit to having a soft spot for the MG Midget.
Remember carburetors, points and plug wires, ring and valve jobs, STP and vacuum operated wipers? Remember when disc brakes were an option? Regular and frequent repairs were the norm for all cars back then.
Steamguy may be kindred spirit. It's possible we could bore you to death about the maintenance required of a 6 cycle external combustion engine and the smell of coal smoke and hot valve oil. His point about oil changes is essential.
The standard oil change interval for the 1600 engines was 3000 miles. Even then they would drop the #3 exhaust valve around 60K. Even with the modified fan shroud for the oil cooler in this engine. #3 still ran hotter. Valve adjustment is necessary every other oil change.
The simplicity of design is the strong point for using an old Bug as a Toad, and surprisingly, parts are still readily available across the country.
I've got a load of old VW stories I could tell you and the good ones have nothing to do with breakdowns on the road.
Have some old Graybeard VW mechanic give it a through once-over. If you can't find one shot me a PM and I'll help you where I can.
Antique car owners don't worry any more about reliability than Vintage Airstream owners worry about soft floors, water leaks and spotty electrical problems. It goes with the territory.
Let's not loose sight of the fact that this car probably is not going to be a daily driver. (If it is we need to have a serious talk).
Being pulled around the country and making 100 mile or so round trips to points of interest will be an ideal use of a Vintage Classic. I'll bet you draw as much attention with the Bug as you will with the vintage Argosy.
So hook the old girl up to the back of the MOHO and enjoy the ride.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-23-2012, 07:29 AM   #33
1981 31' Excella II
New Market , Alabama
The #3 valve overheating problem went away with the dual port 1600 motor that had a dog house oil cooler that did not block air flow to that side of the engine. The older VW engines have an oil cooler that blocked air flow to one side of the engine. I never had overheating problems with mine. It is always a good idea to put a temp gage on the head just in case. An oil pressure gage is a necessity as well.
Perry
Old 07-23-2012, 09:00 AM   #34
1977 20' Argosy 20
The Bug is most definitely going to be a toad only. Will be stored in the garage and used as a tow vehicle on RV trips.
HappyPill77 is offline   Reply With Quote
Old 07-23-2012, 09:05 AM   #35
1981 31' Excella II
Don't let it sit too long. Try to put non-ethanol gas in anything that sits and has a carb. Aluminum carbs with brass jets don't like the corrosive nature of ethanol.
Perry
Old 07-23-2012, 09:17 AM   #36
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Tom's points are well taken. I had in those days several 2 cycle Saabs, a Saab 99 (the first one with all its engine problems), a Saab with an English Ford engine, a TR4A, an MGB, the first non-motorcycle Honda Civic, '63 Volvo, a '72 Jeep—it gets painful to remember. The '72 Chevy pickup was the most reliable, but the others were more fun. I learned how to do 4 wheel drifts in the Volvo and the TR was great to drive, but QC was awful (body started rusting through in 3 years). The Saabs were unequaled in snow. Honda's were not great cars in the early '70's (rust also a problem with those plus oil pump housings, coils…). The MGB's exhaust system was so low to the ground a piece of paper on the road could tear it out (slight exaggeration for story telling purposes) and there were unsolvable problems with the oil system. The Jeep ranks with the worst vehicles I ever owned.
They were bad cars by today's standards.
I'm glad to hear the VW's got better than the '50's and '60's models with all their quirks.
The funny thing is I look back at some of those cars with fondness even though at the time they drove me crazy (sort of like an Airstream). We've bought Toyotas since 1999 and they are reliable and dull.
Gene
Old 07-24-2012, 09:29 AM   #37
Wise Elder
Jammer's Avatar
2010 30' Classic
Looking back at the cars of my youth (that is, the cars of the 1970s and late 1960s), compared to the cars of today, the differences in longevity, reliability, handling, and fuel economy are stark.
In Minnesota we routinely saw fairly serious rust problems on cars after 5 or 6 winters. On one bug my dad bought new, he replaced the fenders and had the whole thing repainted because of rust, after it was about 5 years old, in an effort to keep it nice. Cars still rust out but it takes 10-15 years now.
During that era the fuel systems and ignition systems were notoriously poor as the automakers struggled to comply with clean air mandates with technology that wasn't really up to the job. The 1974 beetle had a complicated system of spark advance and retard that was iffy at best.
Have fun - enjoy the nostalgia - enjoy the looks. But a Ford escort or something would be more practical.
Old 07-24-2012, 01:06 PM   #38
1977 20' Argosy 20
I think what Tom Nugler said in his post hits the nail on the head.
He said: "Antique car owners don't worry any more about reliability than Vintage Airstream owners worry about soft floors, water leaks and spotty electrical problems. It goes with the territory."
An owner of SOB could quite possibly question the practicality of people who own vintage Airstreams.
Old 07-25-2012, 11:29 AM   #39
Washougal , Washington
You must be thinking of a 411 or something else. My beetle distributor was as simple as other years. (although I did work on a certain Asian brand of that era and they were just goofy in the way you're hinting at)
Don't get an Escort from that era... During those years they were only good for about 60,000 reliable miles.
Really not trying to sound like I'm flaming here... I'm just remembering from the day-to-day work of having my hands in cars of that era.
Steamguy is offline   Reply With Quote
Old 07-25-2012, 01:38 PM   #40
DKB_SATX's Avatar
1976 Argosy 28
@Steamguy: I think '71-'73 had a weird distributor with 2 kinds of vacuum advance that was expensive and fiddly to tune. Later ones went back to a more normal single vacuum advance, but lots of people loved to put 009 centrifugal-advance carbs on because they were easier to tune (even though they didn't perform as well off the line.)
— David
Old 07-25-2012, 01:44 PM   #41
Master of Universe
Gene's Avatar
The good thing about that era was it was easy to fix the cars. A Swiss Army knife would fix a lot of things and a match book cover often set the points correctly.
Once computers came along, I was lost. Just in time, because as I got older, I had less and less desire to fix cars, though now I own an Airstream and feel like I'm back in the '70's as far as the technology and QC go.
Gene
Old 09-23-2012, 11:52 AM   #42
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
We flat towed a 71 Super Beetle for years behind our 345. Barely knew it was there. We wired the Beetle up using a "trailer" wiring harness and used a $100 Beetle towbar from JC Whitney.
Worked like a charm.
Gotta say, it drew a lot of attention as gas stations. Classic towing a classic.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
