Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 11-04-2002, 01:24 PM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
toad wiring
I used a tester to wire the 5 pole round trailer light plug into my motorhome. It works fine. BUT- when I plug in the lead from the toad ( a saturn) I get nada.
Seems the wires were frayed on the end, so I pulled off the female plug, and wired it by testing each wire first to see which light at the rear lit up. Still nothing. Any ideas?
Both plugs use a left and right turn(brake also) wire, a Tail light wire, and a ground only.
Old 11-04-2002, 08:18 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Got a real good ground? Saturns have a lot of plastic.
John
74Argosy24MH is offline   Reply With Quote
Old 11-06-2002, 08:07 AM   #3
ALANSD
Right I will check that again. I got another schematic for a Saturn hitch lightplug and tried to rewire to match, still nada. The wire colors seem to match. Would you think if I probe the Saturn end plug with the test light while its turn signals or lights are on, the testlight will light?Seems to me if it does the thing is wired right. I get juice to the cars lights when I run the wires direct to battery and ground. So I know the wires are ok to the car, just something in the plug set up is wrong.
Old 11-06-2002, 10:13 AM   #4
74Argosy24MH
If you are talking about pushing on the brake pedal and checking the plug, as long as it is wired straight through there should be voltage at the plug. Was this wired by you or a PO? If someone put diodes in it to prevent feedback they could be in backwards.
John
Old 11-06-2002, 12:04 PM   #5
ALANSD
I replaced the plug last week with the same type as was on there. It had 4 wires on it as does the one on the motorhome end, but also had one wire not connected which seems to be the ground. i thought if I connected that one to the right terminal it would do the trick, but didn't. I will probe it with the foot on the pedal and see if i can get a light on my tester. Does it matter if the key is on for the motorhome switch to activate the toad lights?
Old 11-06-2002, 01:31 PM   #6
canny_banjo_man
canny_banjo_man's Avatar
Profile:  Yorkshire , England
NOT food ...
Alansd...
Sorry 2 hear abt Yr problem with Yr wires, I can't help U on that one, as U kn, but I am ( as I usualy are ) a little lost here, we EAT toad-in-the-hole over here, ( SAUSAGE in batter )...so I gather it's not that, WHAT is & why is it named a TOAD ???...
On my garbage trailer we have 7 wires, and I spent ages wiring it up to the male plug, only to find out I somehow turned the plug a little, thus putting the matching colours one wire OUT all the way round the plug, still, I got there in the end, I even managed to teach myself some NEW words...much in disgust to my DOG, who scampered off indoors...lmao....Chris.....
It's NICE 2B Important...but it's more Important 2B NICE...Chris.....
canny_banjo_man is offline   Reply With Quote
Old 11-06-2002, 02:15 PM   #7
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
do you have isolation diodes in the toad wiring.?? if not that could be the problem.. i wired isolation didoed into my toad and the only problem i had was wiring errors ..i was advised to use the diodes to prevent the coach dc from getting into the toads electrical system as bad things could happen..
wb13798 is offline   Reply With Quote
Old 11-06-2002, 02:18 PM   #8
wb13798
wb13798's Avatar
use your emergency flashers it will pulse your toads tail lights. and uou can see it with your test light .
Old 11-06-2002, 04:13 PM   #9
74Argosy24MH
Chris- Toad because it is a towed vehicle.
Brake (& 4 ways) and tail lights will work with the ignition off. For the turn signals it has to be on.
John
Old 11-06-2002, 04:48 PM   #10
ALANSD
I guess I am having a brain cramp thanks for the idea about the flashers.
I will try that next chance I get. I believe it could be a ground problem, and will run a new ground and see what that does.
I am not towing the car too soon, but want to be ready for the XMAS vacation.
Old 11-07-2002, 01:27 PM   #11
canny_banjo_man
Toad.
Thank's Alansd for the translation...thinking abt it...must have misplaced my brain-cell, hope U manage to sort it...
There is nothing WORSE than a wiring fault, guess ALL wires are female...put there to test us...lol
B-good...Chris.....
Old 11-10-2002, 12:17 PM   #12
ALANSD
well, I ran a new ground and still get nothing when I probe my test light into the holes on the plug. I am going to splice into the wires and see what I get one by one. arghhhh!!!
Old 11-12-2002, 05:34 PM   #13
zamboni
zamboni's Avatar
Profile:
Where does your ground on the toad side connect?
You say that all the electric comes through the female plug correctly on the MH, right?
And when you touch a known 12vdc + and - source to each respective wire for the toad lights you get each light to light up, right?
The rest should fall into place, with the exception of the possibility of a isolator.
you could check continuity of each wire from the front of the toad to the rear light plug to check actual wiring and which is which with an Ohm meter.
zamboni is offline   Reply With Quote
Old 11-12-2002, 05:35 PM   #14
zamboni
zamboni's Avatar
Profile:
have you traced the "loose" wire to see what it actually is?
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
