Join Airstream Forums Today
Old 05-10-2011, 05:58 PM   #1
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Time for new Bushings. Where to Purchase them?
I see my front sway Bar bushings are Hurt Bad.
I have seen this topic discussed and I am sure some of you have replaced these. maybe with grease-able Units ?
I also just remember reading One of your Posts that Airstream added a heavy duty front sway bar to the P-30 chasis when putting together these units at the Factory. ?
Is that correct.
Thank You for your Help.
Or maybe there is a newer, heavy, Better unit to install. ?
Henderson ?
John H. is offline   Reply With Quote
Old 05-10-2011, 06:05 PM   #2
Images: 13
quote
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil Springs
and this may be the route to go also ? what do you think
Old 05-18-2011, 05:18 PM   #3
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
I just purchased heavy duty coil springs (500lbs or so more lift) but have not found the best solution for sway bar so do tell when you find out.
AirRowan is offline   Reply With Quote
Old 06-09-2011, 11:26 AM   #4
jshle's Avatar
Roadmaster Kit
this is what I went with
Name:	updates, june 2011 002.JPG
jshle is offline   Reply With Quote
Old 06-13-2011, 02:07 PM   #5
jshle's Avatar
ahhhh, now for a Little road trip
Heading for Lake Erie Next week
The Sandusky, a stop at P&S, Helena also, area. so we will git to test the new Kit out.
John and sharon
Name:	new front Anti sway Bar, June 2011 005.JPG
ID:	132391   Click image for larger version
Name:	new front Anti sway Bar, June 2011 006.JPG
Old 06-13-2011, 04:07 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
I used Hellwig bars on the front and rear of my Excursion. They are an after market company that specializes in sway control and I am sure they would have good info on what you need.
Truck & SUV Sway Bars | Hellwig Products
WBCCI 12156 AIR 3144 WDCU TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
Old 06-13-2011, 04:30 PM   #7
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
Parts
If you want standard P-30 chassis parts try Mill Supply they support both Ford and Chey delivery type vehicles and have lots of P-30
bushings springs etc. Mill Supply Index
Frank & Lisa Sullivan
Bfrank is offline   Reply With Quote
Is 6 yrs old time to replace? Tim_S Tires 25 04-15-2011 05:55 PM
First Time on the Road McDonalds On The Road... 17 04-12-2011 09:11 PM
Time for another Maxbrake Jammer Brakes & Brake Controllers 0 03-30-2011 02:01 PM
Good Time to Buy Appliances? EricJohansen Dollars & Cents 0 02-27-2011 02:57 PM
Ugh! It's time for the roof. DougZ Roof 7 02-03-2011 06:56 PM
