Old 04-27-2015, 12:32 PM   #1
Thermostat Replacement
Here's one for you electricians. My Atwood Hydro Flame thermostat has failed - - it will not shut off. It's rating (according to the label inside) is AMP 0.2 - 1.0. A replacement I have, not an Atwood, has a heat anticipator adjustable from 0.15 to 1.2 amps. Both thermostats have have a simple two wire connection. Will the replacement work, safely?
Thanks.
comprose is offline   Reply With Quote
Old 04-27-2015, 01:59 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The new stat cover the range of the old one so thee should not be a problem. Just set the new stat to the same antisapator amp setting of the old one as a starter and adjust if needed.
2004 Excursion 4x4
Old 04-27-2015, 03:10 PM   #3
1974 Argosy 20
Kooskia , Idaho
And if you decide you want a newer electronic digital thermostat, just buy one which has a replaceable battery in it, they use an internal relay to control the furnace and will work very well.
Thermostat replacement jcanavera 2000 - 2004 Safari 7 07-26-2017 08:58 AM
Replacement Thermostat... Kevo Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-30-2011 07:29 AM
Thermostat Replacement ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-14-2006 07:39 PM
Thermostat Replacement Results noiva Mechanics Corner - Engines, Transmission & More... 12 03-18-2006 09:44 AM
Replacement thermostat for Suburban furnace SafeHarbor Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-09-2005 10:14 PM
