12-26-2013, 10:04 AM
1995 31' Land Yacht LE
Hubertus
, Wisconsin
The front end shakes?
My first foray to find airstream wisdom.... Drove the 95 land yacht ( about 60k miles on it ) from Wisconsin to.S Ca for family Christmas. We keep it between 60 and 65 and it feels like I have unbalanced ties with a bouncy shake. However it is intermittent. New front tires within the year. The guy put a little bag of graphite in the tires and said it would perennially balance.? The trip included several long crawls though slow to stop and go traffic. At slow speeds it felt sometimes like a Flintstone mobile...rocking wobble. Checked and filled the front bags to 70-75 no discernible change. Thinking of changing out the steering damper/shock?
12-26-2013, 10:09 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Before trying anything too esoteric, have you considered simply checking the front end alignment?
12-26-2013, 10:12 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
Welcome to the AF Mark. Sorry to hear you have some problems with your unit. Sounds to me like a wheel/tire problem, but one other thing that can cause this type of bounce/wobble, is a bent driveshaft or alighnment of such.
I take that this unit is new to you?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
12-26-2013, 10:29 AM
Hubertus
, Wisconsin
We've had it since 04. Will look at alignment and retest engine/drivetrain empty vs road speed. Maybe that would isolate or eliminate the drive shaft possibility?
12-26-2013, 12:16 PM
Princeton
, New Jersey
If the problem is intermittent I would look at the front brake rotors especially if the problem shows up while braking.
If you do go for an alignment make sure you go to a truck shop and not a car dealer.
2004 Excursion 4x4
12-26-2013, 01:11 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
on an older vehicle you can have an accumulation of wear in the front end. while installing new dampener(s) might help a thorough front end check it needed. often a bump starts the oscillations. hopefully it is something simple like a bad tire or a thrown weight.
Ricky
12-26-2013, 03:27 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Of course everyone has their own opinion and mine is this. I would jack up the front end and check the following:
Wheel bearing end play
Tire rods
Steering link
Ball joints
Bent wheel
If you are not mechanically inclined or inclined to do this yourself, as mentioned before a reputable frame and alignment shop that specializes in trucks can check these items for you. Also take the technician on a test ride. He would probably enjoy and also get a feel for your concerns,
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
12-27-2013, 10:26 AM
1984 31' Airstream310
Honokaa
, Hawaii
The fact that you feel it at very slow speeds says "tire" to me, here is another thread on an older Argosy with similar symptoms:
http://www.airforums.com/forums/f160...ce-111136.html
