Old 11-02-2005, 02:10 PM   #1
Airstream Classic
Tail slap on 345
My favorite camping spot has a sharp hill to negotiate and I'm concerned that rear end of my 345 will hit the ground if I try to make it this year. Has anyone had this problem or know of a way to lift the rear end with an on-demand solution? I would hate to go back to tent camping for this annual event. If I get stuck, I'll be in real trouble.
airstream963 is offline   Reply With Quote
Old 11-02-2005, 03:13 PM   #2
1994 30' Excella
Mississauga , Ontario
Have you thought of using air bag suspension add on to supplement your regular suspension. With an on board compressor you could fill them and raise the rear only when you need it. Check out "Air-lift" or Firestone for ideas.
Al
You got to go in your mo-ho.
Old 11-02-2005, 03:22 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
345's already have air ride on the tag axle.The only other thing I can think of off the top of my haed, is to put a pair of those small roller bogies on the bottom of your rear bumper. At least theoretically if you do get hung up, someone with a good sized pickup can pull you back out, as you will still be on wheels, albeit small ones.
Old 11-02-2005, 05:50 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Tail dragging is an issue on the 345. We have a steep entry into our driveway at home and whenever I'm backing into the drive I make sure I go in with enpty fuel, water and waste tanks. I also make sure the rear bags are at full pressure and the fronts are emtpy. I also go up the ramp at about a 45 degree angle. It make the difference between dragging the skids under the fuel tank and not. Even with all of these changes it's only about an inch or so difference.
Having said this, there were a few times, early on, when I've pulled into or out of a parking lot and scraped the tailskids. Ever so slightly but it happened. I've learned to attack these entries at an angle, or avoid them altogether.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-03-2005, 05:36 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
This happens even with the shorter MH's, but of course not as severe as with a 345. When I first got mine, in a touristy mountain town near here I tried to negotiate a left turn and uphill entrance to a parking lot...quite steep.
Got my trailer hitch stuck in the asphalt on the main road, blocking traffic. I couldn't go back or forward...finally had to pull up dragging it and cut the wheel to get out again dragging it. Nice sounds for all to hear.
I should add that keeping my air bags full has reallly helped with this issue.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-03-2005, 07:58 AM   #6
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
You have several options.
1) get a roller for the hitch. Camping World sells them. If you bottom out, the roller keeps you from getting stuck.
2) take the hill at an angle if possible. That helped in my 345.
3) I also used 2x6 planks under the tires in the valley. They doubled as my jack stands
The previously mention items are also very helpful. Your tanks are all behind the rear tires so draining them is a big deal (of course you need gas). I took my 345 to some pretty wild places. We called it Extreme Camping. We did hit Black Rock Mountain in Georgia up a 17% grade and around some sharp turns up to the HIGHEST camping pad. Alan, have you taken your 28 footer there yet? Nice place. We laid in bed and watched the sunrise through the wrap around windows. Way cool.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 11-03-2005, 08:34 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
not yet, but recently went to Fort Mountain, it was fabulous.
AIR #005
retired!
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
345 Hill Climbing ViewRVs Mechanics Corner - Engines, Transmission & More... 12 04-18-2002 11:52 AM
