Old 08-22-2003, 08:50 AM   #1
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Tag Axle Oil Level?
OK...got one for the 325 and longer crowd. My 86' 345 has Alcoas with those big truck style chromed axle covers on both the rear drives and tags. The covers on the drives are completely enclosed one piece units but the covers on the tags have those little clear plastic plugs in the center with a smaller rubber plug within the plastic plug (I've seen these on commercial trailers before). They have two circular graduated lines on the clear plastic for an oil fill level.
What concerns me is that both sides are bone dry. So dry in fact that I don't think they have ever had oil in them. I just noticed this fact after putting nearly 3000 miles on the coach (without any obvious issues with the tags).
So what gives? Is oil supposed to be in there? Are they simply a truck stop replacement and I can ignore the fill lines? Again, without the coach/chassis manual (yet) I'm guessing at this kind of stuff.
As always everyone's advice is welcome and appreciated!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-22-2003, 11:19 AM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
I actually have some paperwork on the tag-axle. I will be busy doing other things so kick (PM) me if I forget to check my documentation!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 08-23-2003, 05:54 PM   #3
uncleneal's Avatar
Fred,
Please post what you find out. I have an 85/86 345 with the same covers on the tag axles, but no plug in the hole. When I filled them with 90w gear oil, it just runs out past the lugs everytime I move the coach. I plugged the holes with electricial knockout plugs and duct tape - couldn't find the plastic plugs. A friend has an 86 345 - his has solid caps, and regular trailer type wheel bearings with grease.
Thanks, Neal
uncleneal is offline   Reply With Quote
Old 08-23-2003, 06:06 PM   #4
ViewRVs's Avatar
1977 20' Argosy 20
I dug through all my stuff at home and I didn't find it. I think I stuck in one of my overhead bins. We are going over to the storage center tomorrow so I will check!
Fred H.
Old 08-24-2003, 04:48 AM   #5
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I have a 1984, 345 Motorhome. I have the solid covers on the tag axle wheels. I have taken them off to check the brakes and found that the axle has the standard wheel bearings similiar to the front wheels or trailer wheels. No place to oil.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 08-24-2003, 07:12 AM   #6
RivetAddict
swebster's Avatar
Mine appears to be the same (greased bearing trailer axles). Now I'm wondering how these axle covers got on there and if they were original AS was there a reason for them?
Steven Webster
AIR 1760
Old 08-24-2003, 12:53 PM   #7
uncleneal's Avatar
The reason may be as simple as that's what they had available when they built the '86 model. Seems like I've seen one that had rubber plugs that had the Airstream logo on them.
My xeroxed service manual gives a good bit of info about the tag axle brakes and the air suspension system, but dosen't say anything about the bearings or lubing them.
You could do like I did and put some oil in there. If it runs out past the lugs like mine did, it obviously dosen't have a seal to keep it in, and wasn't intended to have oil in it. Makes a fine mess on the Alcoa wheels.
Neal
Old 08-24-2003, 05:51 PM   #8
RivetAddict
swebster's Avatar
I suspected this too. Perhaps they were a replacement at some point. Both rear covers seem to be SS and look fine the fronts are chrome and have rusted badly. I've taken to browsing the "chrome" ailses at larger truck stops and even online looking for replacements for the front (along with lug covers) and perhaps the tags now as well.
I've always wanted to do that - now I have a valid reason to! All of those bolt on lights and chrome...I can't help myself, I just steer over there.
Steven Webster
AIR 1760
Old 08-25-2003, 04:49 AM   #9
ViewRVs's Avatar
1977 20' Argosy 20
I dug through my 345 yesterday and could not find the paperwork I thought I had. Sorry.
Fred H.
Old 08-25-2003, 05:01 AM   #10
RivetAddict
swebster's Avatar
Fred,
Thanks for looking. I think those of us that have looked all think that the tags are just greased bearing axles. Not sure how these hub covers got on there but I feel safe to replace with solids after looking at the hub itself.
Steven Webster
AIR 1760
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Tag axle brakes for 350 classic Marshall Walters Airstream Motorhome Forums 1 08-29-2003 05:42 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
