Old 07-11-2013, 12:39 PM   #15
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
As a machinist who has assembled and disassembled many interference fits heat is your friend. Cold helps in assembly but is very difficult to effectively apply to an assembled unit. Heat the hub of the wheel. It will also heat the shaft but not as fast and sometimes it is just enough to break it loose. Also several heating and cooling cycles can help a stuck joint. Another thing is forget the impact wrench. Draw the center bolt of the wheel puller tight and then smack it firmly straight on with a large hammer. That is the impact that the joint will "feel" and break it free.
Draw the puller center bolt up tight, heat the wheel hub and strike the puller center bolt. Let cool and repeat. You don't really need a lot of heat. A small pencil type propane torch applied right at the joint will do the job. The joint is designed to come apart without heat but the rust and corrosion formed over the years is your problem and the heat and cooling cycles will help free that up.
Also the puller shown by Robert is common but there are also many with three legs rather than two. It depends on the wheel which you need. And forget the jack, you will damage the column and not help get the wheel off. Good luck.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-11-2013, 01:21 PM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Better solution? Thanks!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-11-2013, 10:06 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oops!
I did not mean to post the above with a Question mark....
I absolutely agree the last full post was excellent,,,,
thanks for allowing me to correct my error...
Channing
WBCCI# 30676
Old 07-12-2013, 12:20 AM   #18
Oops!
Not to worry, my poor old eyes never noticed the ? My problem is that my two finger typing is so slow that in the time it takes me to type a response two more people have already posted the answer. All we can do is put forward our best efforts and hope it helps somebody as much as other people have helped us.
Cheers, Dan
Old 07-12-2013, 05:20 AM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
How about a vertical photo of your puller set-up?
That may help....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-13-2013, 01:20 PM   #20
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
You mentioned that you are using WD40 to help breakdown the rust. I have had much better luck with PB Blaster. I would put PB Blaster on it for a couple days.
Gregsch is offline   Reply With Quote
Old 07-21-2013, 07:50 PM   #21
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Fallbrook , Southern California
Send a message via Yahoo to abridges01
Oh yes, liberal application of heat with blow torch and persuasion from club hammer finally persuaded first steering wheel, then boss to let go of splined shaft! Thanks to all for helpful advice, now all I need is a new horn slip ring and actuator as the old one melted!
1975 26' Silver Argosy MH: Ethyl the Never Ready!
Fallbrook, Southern California
"Experience is something you never have... until just after you need it!"
abridges01 is offline   Reply With Quote
Old 07-21-2013, 08:59 PM   #22
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sahweeeeeet!
Channing
WBCCI# 30676
Old 07-21-2013, 09:38 PM   #23
It looks like the shaft and splines are still in pretty good shape. At this point in time that is a real plus.
Cheers, Dan
Old 07-24-2013, 07:20 PM   #24
I might be able to help with the slip ring. I've got a spare steering column for parts.
I will need to pull the steering wheel first however
bkahler is online now   Reply With Quote
Old 07-30-2013, 03:04 PM   #25
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
That would be wonderful it you can Brad as, to date, I have been unable to locate a spare. I just hope you enjoy better success removing the steering wheel than I did!
Cheers,
Andrew
Old 07-30-2013, 05:19 PM   #26
Is one of these the ring you are looking for?
Truck Parts | 1969-1972 | 1967-79 STEERING WHEEL / HORN CAP MOUNTING SET | Classic Industries
Cheers, Dan
Old 08-10-2013, 06:42 PM   #27
Andrew,
Got the steering wheel removed this evening. Popped right off with a little assist from the impact wrench
Which parts do you need?
ID:	192878Click image for larger version
Old 08-11-2013, 10:08 AM   #28
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
That's great news thank you Brad. The part/s I'm after is the copper/black plastic slip ring that the little metal rod and spring horn actuator contact when the horn boss is pressed.
ID:	192911   Click image for larger version
