Old 06-29-2004, 09:32 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
stripping the grey painted bottom
I am getting cloe to repainting the grey bottom area....have any of you stripped this with aircraft stripper or ? Some of it is plastic at the bumpers, but the rest is painted aluminum. The doors to the storage boxes included. I would love to leave it clear aluminum, but repainting will probably work out better.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-29-2004, 12:12 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Alan, I used a waterbase stripper to remove the paint from the plastic parts. Any other stripper will eat the plastic in no time. Any paint store or Home Depot carries the waterbase stripper.
Dont' leave it on too long, have a waterhose close by to rinse it off. Then I used a lacquer automotive primer, which after several coats and sanding between coats left me with a good surface for the finish coats.
Any stripper will work for the aluminum parts. If u decide to leave it aluminum, be prepared to find some rough spots that will require sanding before proceeding with the polishing steps.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-29-2004, 01:27 PM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I picked up som estriper at West Marine on US41 (same shopping center as Scalini's) that is for use on fiberglass to use on the inside fiberglass end caps. It's probaly just a water base striper as Peter was recomending but you might hit their website and see what they have. The couple times I have been there the folks were knowledgable on the products they had on the shelf.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 06-29-2004, 04:36 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks guys. i will try the water based stripper on the aluminum and plastic areas. If the aluminum comes out ok I might go ahead and polish it out and forget the grey paint. I love that look. The Ii can just redo the spare tire cover and end parts in grey.
AIR #005
retired!
Old 07-08-2004, 03:20 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
well I bought the Klean Strip premium spray on for the aluminum lower. Got some good gloves, and will jump on it soon. I will post photos of the progress. Also found some nice glossy grey paint in case the stripping idea doesn't work out.
AIR #005
retired!
Old 07-09-2004, 10:50 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
well it seems to be going quite well. After 90 min or less I have 3 panel areas almost done. Its way too hot (92) to do a lot more today, but i will get a lot accomplished for the first wack at it. Here are the before, and during shots.
ID:	7606   Click image for larger version
AIR #005
retired!
Old 07-11-2004, 07:33 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
One side mostly done, now I will polish it out some, and seal with the same stuff I used on the upper areas. Then on to the driver's side. A rewarding project thus far.
AIR #005
retired!
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Retrofit grey tank mod uwe Waste Systems, Tanks & Totes 33 03-08-2006 07:50 PM
permanent decal & paint stripping 0557 Our Community 1 02-19-2004 05:44 AM
grey water plumbing vent Cruiser Waste Systems, Tanks & Totes 6 07-14-2003 02:03 PM
Bottom Band ? SAM Belly Pans & Banana Wraps 2 09-28-2002 08:33 PM
