Old 10-17-2013, 05:48 PM   #1
1985 34.5' Airstream 345
Stark city , Missouri
starter aux switch
My wife and i just inhereted a 1985 345 motorhome, we are excited to get started, however we have a question on some motorhomes there is a switch that connects the house batteries to the engine
battery (if needed) does the airstream have this?
Thanks in advance
Farm 1 is offline   Reply With Quote
Old 10-17-2013, 08:13 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Congratulations on your inheritance, and welcome to the forums!
On our 1984 310, there is a solenoid mounted on the back of the battery tray that automatically connects all of the batteries when starting the motor. It is the one on the upper left in the attached photo.
I understand that some 345 models have a switch in the glove box that you pull by hand to accomplish the same thing.
Waipio Rim is offline   Reply With Quote
Old 10-20-2013, 12:46 PM   #3
That's interesting. Our 84 310 has a switch in the glove box to tie them together. I know it works as I had a starting problem a while back and the switch saved the day.
I wonder if your arrangement is factory or a PO mod.
Old 10-20-2013, 01:28 PM   #4
1974 Argosy 20
Kooskia , Idaho
My '83, 310 had the automatic switching that Waipio mentions, with no dash switch. It was factory that way on mine.
Old 10-20-2013, 03:14 PM   #5
Interesting. I will admit the switch installation is kind of kludgy which is why I assumed it was a factory installation
I'm assuming the solenoid is just connected to the starter solenoid wire.
Old 03-25-2014, 09:12 PM   #6
Auretrvr's Avatar
Iowa City , Iowa
My Starter Assist (Aux) switch solenoid shorted out...
Last summer my chassis battery was draining while boondocking so I put a switch on the battery to disconnect it while boondocking.
Then I noticed that I could start and run the engine with the chassis battery disconnected! And could run the house lights with the engine stopped and the coach batteries disconnected! And boondocking still drained the chassis battery.
So it was a shorted Starter Assist switch solenoid. I replaced it along with the isolator and all the batteries (Long Story).
Just discovered the 'new' solenoid is shorted. Is this a coincidence or am I missing something here?
Have not replaced it yet but I've bypassed the solenoid, disabling the Starter Assist button. I have jumper cables If I need a boost.
Now the engine generator sends juice to the coach batteries and circuits when the engine is running but not when it is not. In other words the isolator is working and and there is no longer a persistent connection between chassis and house batteries. Boondocking is not draining the chassis battery.
Have you seen this kind of problem before?
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 03-27-2014, 11:09 PM   #7
1974 Argosy 20
Kooskia , Idaho
It does sound like your new solenoid is defective and not releasing. It should only connect the two battery sets when the starter is engaged or when the boost switch is operated, depending on which system you have in your coach.
There are a lot of different solenoids that look alike but have different internal wiring. Is it possible you got the wrong one, or have the wiring wrong?
Old 03-28-2014, 08:32 AM   #8
1995 36' Classic 36
Ludington , Michigan
The AUX battery momentary switch in my dash is bad. I'm considering removing the bus tie solenoid as I don't see a need for it.
Kota is offline   Reply With Quote
Old 03-30-2014, 06:29 AM   #9
Auretrvr's Avatar
Iowa City , Iowa
I can never rule out 'User Error!'
Thanks, it did work work at first--the two high amp pins are indifferent but there are two posts for actuating it--start, and ignition. I have that attached right. I'll pull it out and take it back to the store!
AIR 15765
Old 06-25-2014, 11:57 AM   #10
345bill's Avatar
Las Vegas , Nevada
On our 1990 345LE there is a momentary toggle switch inside the glove box that ties all batteries together if start battery needs a jump.
345bill is offline   Reply With Quote
