Old 09-13-2017, 12:55 PM   #1
2006 39' A-Series
Prescott , Arizona
Solar system on A Series
I have an 2006 A39 with the factory installed solar system. It has 2 BP solar panels, which I believe are about 50 watts each. The solar system is not able to keep the batteries changed, even in the bright Arizona sun and the house switch "store" and I believe the problem is with the solar charge controller. Both the house and chassis batteries go dead. (I had problems with the solar controller on my previously owned 390XL so I am pre-conditioned to be suspicious of these.) My question is does anyone know where the solar charge controller is located? I have talked with a person at Intellitec, the manufacturer of a display located above the refrigerator, but he says this is a simple charging/charge LED display and not the charge controller itself. I have tried tracing wires, but have not been productive. Any suggestions? Thanks.
jwitwer is offline   Reply With Quote
Old 12-09-2017, 03:01 PM   #2
gregwall's Avatar
2014 25' FB Flying Cloud
2005 30' Classic
Keswick , Virginia
I'm sorry you haven't gotten any responses. I just saw the post. Did you resolve your problems?
Greg
2014 25' Flying Cloud FB
2015 GMC Sierra Denali 6.6L diesel
Charlottesville, Virginia
gregwall is offline   Reply With Quote
Old 12-11-2017, 12:53 PM   #3
2006 39' A-Series
Prescott , Arizona
I think I've figured it out.
Greg,
Thanks for your thoughtful reply. I guess I should have posted this sooner: I did not get any other replies, but I also think I've figured it out. It looks like the solar charge controller is a small add-on circuit board attached to the IntelliTec battery control board. This larger control board is located in the fore-most curbside storage compartment. The panel over the refrigerator is simply a state-of-charge display, not a controller. I'm still not certain if mine is working properly, so for now I've simply taken to disconnecting the batteries if it is sitting more than a couple of weeks.
Old 12-12-2017, 03:22 AM   #4
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
A picture of the state of charge display would be helpful. It might be a Magnum, which will show state of charge listed as volts. Batteries going dead is not a good thing. Once they go below 50% charge, they won't fully charge again, assuming they are lead acid batteries. 12.06V is 50% charge. Even if you have two 100-watt solar panels, they won't provide enough power to run everything in the coach. However, it can be a big help, especially in Arizona and when you are not driving it. First I would check the batteries: how old are they, what kind are they, what is their state of charge and how many amp/hours do they hold. You were right to disconnect them when it is sitting. Let me know what you find out about the batteries.
Greg
Old 12-12-2017, 03:34 AM   #5
gregwall's Avatar
2005 30' Classic
Keswick , Virginia
A good description of Airstream's very basic solar system is: https://www.coltonrv.com/optional-solar-panels/
Sometimes these links don't work on airforum, so let me know.
Greg
Solar panels in series or parallel - but why not both? drboyd Generators & Solar Power 19 10-16-2017 08:39 PM
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 04:35 PM
