Old 06-16-2003, 07:59 PM   #1
Crsoley Kid's Avatar
Lightbulb Small tank
We have a 1993 Land Yacht - 33ft. Was looking under the kitchen sink & found a small tank with an air valve in the top of it, looks about 4-5 in. in dia. Any ideas what it is? Will pull the panel off tomorrow to get a better look where it goes.
Crsoley Kid is offline   Reply With Quote
Old 06-16-2003, 08:30 PM   #2
That is what is known as an "accumulator tank".
In theory, it will even out the pulsing output of the 12v water pump, reduce the amount of cycling of the pump, reduce or eliminate surging, and contribute to world peace. No, really, they appear to work in many situations.
The schraeder valve is for adding air. The tank needs a given air pressure to work properly, which I believe is determined by the lower demand limit of your pump.
Mark
Old 06-18-2003, 05:57 AM   #3
Mark,
Thanks for the reply, we have only been out in it once so haven't use the pump much stayed at a state park with water hook up. Went to Texas last winter. Will be goin g to a Crosley Car rally in Ohio next month. Will get to use the water pump then.
Paul
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
