Old 08-30-2003, 07:20 PM   #1
Side Door Window
Iím looking at a 1981 28í Excella motorhome that I may purchase. There isnít a window in the side door. I notice some have windows, some donít. Does it depend on the year or was it and option?
Is it possible to put a window in the door?
Having never owned an Airstream Motorhome, what should I be looking and checking before I purchase it?
Gary Greenwood
Leslie, MI
gcgreenwood is offline   Reply With Quote
Old 08-30-2003, 08:04 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Lee,
Yes it is possible to add a window, the biggest issue is finding the actual window. It will more than likely have to come from a salvage yard.
As to the things to check:
Normal RV appliance checkout, Make sure the AC and refer work. They are 2 of the biggest cost replacements. Drive train is much like any used car, except the fact that the rear suspension is Air Bags. These need to be checked for rot. Genset should run and be able to run the roof air. Tanks should hold liquids and not leak.
If all of those things are in Ok condition everything else can be fixed as you go. Upholstery, drapes and flooring are areas that if it is new and you like it, bonus. If you feel it is a bit worn and needing replacment you may be able to do some dealing, but almost everyoune replaces it to match their tastes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-31-2003, 11:19 AM   #3
Motorhome and trailer entrance door windows are avaliable.
You will also need an interior closeout with it.
Additionally, you can have a shade with it as well.
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
Side window replacement davespann Windows & Screens 8 08-01-2003 04:53 PM
side view mirror broken Astrodokk Airstream Motorhome Forums 5 07-13-2003 06:57 PM
MH side window frames Bfrank General Motorhome Topics 6 04-15-2003 11:15 AM
