Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 08-11-2003, 08:49 AM   #1
mcostanzo
mcostanzo's Avatar
Profile:
Shower "door" leak
Since the trailer was new, I have noticed water getting into the toilet area when the shower is used. I assumed the water came from not closing the shower enclosure fast enough. So I decided to add some tub sealing tape (Home Depot) at the various wall/floor interfaces in the toilet area. My idea was to prevent any water escaping from the shower from going places where it could eventually rot the subfloor.
I did that, and in the process had a close look at the bottom of the shower door track. I found that it had not been properly caulked; there was about 4" where there was zero caulking. That's where the water was exiting the shower. Anyway, I figured that some of you folks with recently built units may have the same problem and not know it. Seems like a good way to prevent those downstream problems with rot.
Mike
mcostanzo is offline   Reply With Quote
Old 08-11-2003, 09:37 AM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Quality control
I'm puzzled by these lapses in quality control at Airstream.
Caulking seems to be one of the weak spots, I still have various gobs on the roof including a gob on the vent cover for my rear Fantastic Fan.
My AC drip tube connection had gobs of sealer where it connected to the pan and still leaked because the sealer hadn't bonded to the plastic.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Outdoor shower idahosafari Sinks, Showers & Toilets 19 04-12-2004 07:48 AM
Shelf Doors/ Shower Curtain question srgntpepper 1963 Safari 5 01-06-2004 05:03 PM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
