Old 09-09-2003, 12:03 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Screen door
how is your screen door held closed? Mine has a small aluminum piece that looks like an afterthought which clips under a slide.
Always coming loose, causing the doors to swing seperately when opened.
Old 09-09-2003, 12:57 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Alan, mine has the same slider that goes over the aluminum bracket that is welded to the screen door. I am planning on replacing it with the same spring loaded catch that is used as a door hold back on my coach. It will retain the door while closed and assure me that when I open the outer door the screen will go with it.
From Inland RV's site, but they are available at any Airstream dealer:
Latch, Plastic, Main Door Holdback, Used with Part #18781 (Note: Parts #18777 and #18781 are now used for the screen door to entrance door latch. You may have to fabricate a shim)
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-25-2004, 11:53 PM   #3
tinsltootsie's Avatar
latches from inland
I saw this thread when looking into screen door latches for my74. Will Inland's work for a 74? I am left with a plastic catch on the side wall, and part of the latch on the screen door itself. Thanks for any info.
Debbie
tinsltootsie is offline   Reply With Quote
Old 06-26-2004, 09:27 PM   #4
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Debbie,
If you can post a picture we may be able to help. There are just too many variables when it comes to the screen door parts past and present.
Brett G
Old 06-27-2004, 05:39 PM   #5
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Brett & Alan,
Mine is the same "tab with slider" setup. I've been thinking about installing a spring button behind it to place a little pressure on it keeping it closed.
It tried bending the tab back a little but there was too much of a gap to make up for. Let me know if you come up with something clever here.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-11-2004, 09:58 AM   #6
IPM
1996 clipper gas 34'
Blue Springs , Missouri
another related thread, I figured out inland forgot to send me the catch.
http://www.airforums.com/forum...een+door+latch
It's all good
IPM is offline   Reply With Quote
Old 08-11-2004, 03:22 PM   #7
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
hey guys i have cussed my screen door for three of four years. one day about 3 months ago i decided i was going to fix that piece of ui093 i took a pair of line mans pliers and squeezed the rear end of the slide . wolla it worked problem solved . if you do that mod be careful you could ruin the slider it doesnt take much to tighten the slider up.
dont be bending the tab on the door unless you have a friend who welds aluminum.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
lock of screen door on 16 foot-Bambi gloriajoan 1997 - 2004 Bambi 10 10-16-2006 03:30 PM
Screen door latch APB General Interior Topics 2 03-10-2003 08:06 PM
