Old 02-22-2015, 04:23 PM   #1
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
Question Rusty undercarriage, how much?
Hi folks,
I wasn't sure where to put this post. I did a search for undercarriage and found a couple of very old posts. Maybe the technology has improved.
We have rust on many parts under our 345 MH - axels, brake lines that were then replaced, I'm not ever sure what all the parts are that I'm looking at when I climb under there. A couple of garages in Portland said they could spray it with something but the rust would continue underneath. Is it a huge, expensive, impossible job to really remediate rust? What would or should it cost these days?
When our mechanic replaced the brake lines, he said the rust on the axles was still pretty superficial. We just removed the old propane tank which was looking pretty bad. We're not sure how much more to invest in the coach given the rust.
Here are the most recent pics, taken a couple of years ago. I'm not near the coach now. Thoughts would be most appreciated, thanks.
Jenniflow is offline   Reply With Quote
Old 02-22-2015, 06:42 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Ours looks worse, but since it is in Montana I am not worried about it. Most 25+ year old vehicles will have surface rust underneath. In really humid climates or places where the roads are salted rust can threaten the frame, but if your coach stays in California most of the time it won't be an issue. I have bought cans of spray on undercoating at Walmart to use on my trucks here in Hawaii where rust is an issue.
Waipio Rim is offline   Reply With Quote
Old 02-22-2015, 07:15 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Light rusting that is relatively uniform over the whole surface usually will not weaken anything enough to make a difference. However, if you do a detailed inspection and find any deep pitting, that's a fracture waiting to happen because there is a loss of strength due to the missing metal at the pit.
If you find deep pitting, one possible solution is to remove the rust all the way to good metal, fill the hole with weld metal (professionally, not a job for amateurs), and then machine it smooth to the original shape, along with peening it with a ball peen hammer to remove residual stress in the metal due to the heat from welding. And here you were probably wondering what a ball peen hammer was good for…
That's assuming, of course, that you don't have a source of replacement parts to simply swap out rusted parts.
Cats and ultraleather Airstream upholstery don't mix!
Old 02-22-2015, 08:00 PM   #4
Jenniflow's Avatar
1982 34' Limited
Thumbs up No pitting, no fussing
Thanks both of you. I guess I need to ask the garage that has it to tell me if they've found any serious pitting. I can instruct someone to deal with that. Overall rust remediation just causes me to lose the will to live.
There are too many other issues that I have to deal with just to make it roadworthy for Burning Man. I got lucky enough to get tickets, now I have to make my Airstream shelter desert-worthy.
Old 02-23-2015, 08:33 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Obviously you haven't seen the underside of cars from any Northern States. They are way worse than that. Surface rust can be caused by moisture in the air, being too near the coast and other climatic issues. I would not worry about it..Go on living!
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-23-2015, 09:36 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
From what I see in the pictures, there is nothing to worry about for the next 20 or thirty years.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 02-23-2015, 09:46 AM   #7
Jenniflow's Avatar
1982 34' Limited
Thumbs up Awriiiiight!
Yay! Thanks so much for that reassurance. I actually grew up on the East Coast but did not spend much time under cars so I wasnt sure how to evaluate the anxiety of coastal Californian mechanics who apparently are not used to seeing much rust.
Old 02-23-2015, 11:14 AM   #8
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
surface patina looks fine, ready for antique roadshow
that exhaust pipe will perforate .... eventually, just keep an eye on it so you don't gas yourself
timhortons is offline   Reply With Quote
Old 02-23-2015, 02:27 PM   #9
Jenniflow's Avatar
1982 34' Limited
Thumbs up Antiques roadshow here I come!
Old 02-23-2015, 05:01 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
also just so you know, if you looked for Chassis or Frame you would have found more posts then you could stand to read.
Best of luck to you
AIR #005
retired!
Old 02-23-2015, 06:51 PM   #11
Jenniflow's Avatar
1982 34' Limited
Thumbs up wrong search term
I knew I was using the wrong search term, but I forgot to ask what the right ones were. Thanks!
Old 02-23-2015, 10:31 PM   #12
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
That wire or string wrapped around the axle (or something else) shouldn't be there. Just sayin'.
Marty Womer
Old Orchard Beach, Maine
MaineStreamer is offline   Reply With Quote
Old 02-24-2015, 12:28 PM   #13
Waipio Rim's Avatar
Honokaa , Hawaii
That's not just a wire or string, it's a Reluctant Leveler Retention Bracket. I have one too.
Old 02-24-2015, 04:42 PM   #14
Jenniflow's Avatar
1982 34' Limited
Talking The Reluctant Leveler Retention Bracket!
Hahahaha! That's exactly what it is, MaineStreamer! And that's what I'm calling it from now on.
Undercarriage Rehab Del Gurney Jacks, Stabilizers, Lifting and Leveling 18 07-25-2013 07:56 AM
Axle bent rubbing on undercarriage Modern South Axles 9 03-29-2013 09:38 PM
Winter Overhaul of 1968 GT undercarriage Randy Gates 1965 - 1969 Globetrotter 5 05-10-2011 08:10 PM
Airstream Undercarriage Rustproofing Mifair Axles 3 11-21-2010 08:26 AM
2007 Safari undercarriage valves woodedareas Plumbing - Systems & Fixtures 3 05-13-2007 02:28 PM
