Old 06-15-2003, 07:40 PM   #1
Orland Dewey's Avatar
Rusty screws in side windows (galvanized)
I have just bought a 325 A/S 1985 MH
Doing lots of repairs on it. The small screws
that are used on the aluminum windows all around
vehicle have small (#6) scews. All rusty and rust
running down window frames. I was able to remove
6 on two windows and broke off 2 on 1 window.
I am replacing them with Stainless #6 screws.
Look good when done. I need help in removing the
remainder screws with out breaking them off. Looking for a better method than I am using.
Orland Dewey. e-mail (mixednuts@torchlake.com)
Thanks I will have many more questions.
ODD
Orland Dewey is offline   Reply With Quote
Old 06-15-2003, 07:50 PM   #2
Try a penetrating catylized penetrating oil. I have had good luck with PB Blaster. Spay it around the head, let is soak a day or so. I think you will have much better success.
Failing that, try a bit of heat. The only practical way to do that is with a high wattage soldering iron. Apply the tip to the screw head.
Mark
Old 06-16-2003, 05:25 PM   #3
rusty screws
Thanks for the tips Mark. I will try the heat
system. I tried the rusty bolt liquid all ready
and didn't work to well. Maybe I didn't let it work long enough. They are so rusty that the
Phillips screw drivers don't work well. I finally used a small pair of Vice Grips to grab hold of the heads and of course thats when they broke. So now I will have to drill out those two.
Thanks so much for the reply...
ODD
ODD
Old 06-16-2003, 10:29 PM   #4
LOST , Hawaii
I've used a die grinder with a narrow cut off wheel to make a slot in the head. It puts some heat into the screw and gives you a slot for a flat tip screwdriver.
John
74Argosy24MH is offline   Reply With Quote
Old 06-17-2003, 08:42 PM   #5
rusty screws
Thanks john that sounds like a good idea too.
I have a die grinder and thin wheel so will give it a try.
ODD
ODD
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
Leaky Windows & Skin Replacement PizzaChop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-08-2004 11:13 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
sliding side windows and tomatoes 26Argosy.ca Windows & Screens 3 05-18-2003 11:02 AM
