Originally Posted by 74Argosy24MH
Will it fit in the generator compartment? When I had to replace the one in my 74 Argosy the only one that would fit was the Onan. The good part of that is they are 2 cylinder and run at 1800 rpm. There is less vibration and the noise level is lower with this type of engine. Honda's are also good, but wouldn't fit through my opening.
It takes a lot of adapting any time you change. Mine was a long way from a simple r&r. I had to build all new slide mounts and carriers for the electrical and fuel line. You do need a lot of free air opening to cool these. The RV ones have a lot more ducting to provide the proper cooling. Despite the cost difference I would go with one that is designed for the limited clearance and harsher environment of a motor home.
John
................I'll respond , even though this post is getting close too 4 years old . MOST , RV specific gensets run at 3600 rpm whether gas or diesel . Specifically , the TWO that Run at 1800 RPM are the Onan , 3 cylinder diesels rated for 10kw and 12kw . The 5.5kw , 6.5kw , 7.5kw , and 8kw(diesels , all).....ALL run at 3600 rpm's . And , All the Onan gas RV gensets run at 3600 rpms . r66
