Old 05-22-2018, 04:02 PM   #1
1981 28' Airstream 280
San Francisco , California
Removing Engine Cover in '81 28' Excella
Hello Experts: Question ... I want to grease the water pump as I have read it has a zerk fitting but I can't see it from below. My Excella has the Izusu Diesel.
I can lift the interior engine cover but still can't see it - thinking the entire shroud should be removed (lid and fixed back portion of box that the lid is hinged to) but mine is fully carpeted and don't see a way to remove it without pulling up carpet.
Before I pull up the carpet I just wanted to hear if I'm on the right track and if so are there particular bolts I should be looking for so I pull up less carpet?? Thanks and best, Dave
redfalcon507 is offline   Reply With Quote
Old 05-23-2018, 12:23 AM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
There used to be a radio and tape deck between the dash and dog house, engine cover. If it is there slide it toward the rear of the coach, disconnect the wires and remove the entire unit. Forward of the hinge is a metal panel about 8" deep held down by about ten 1/4" bolts. Remove the bolts and the entire dog house cover can be removed. If the radio unit has been removed and carpeted over you will have to pull the carpet back to reach the bolts.
There is a sticky thread at the beginning of the Classic Motorhome section that has manuals for your coach. If you have a problem I have them in pdf I can email you. Send me a PM with your email.
Cheers, Dan
~ Margaret Thatcher ~
Old 05-23-2018, 05:33 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
The bolts Dan refers to are around the perimeter of the cover. I had the same question when I got my 310.
mayco is offline   Reply With Quote
Old 05-23-2018, 04:24 PM   #4
Dan again thank you ... send PM. best, Dave
345 engine cover console, organizer or drink caddy Baywatcher Classic Motorhomes 2 04-24-2016 12:52 PM
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
Losing engine elec. engine dies while driving Clyde Gartma Airstream Motorhome Forums 4 12-10-2011 08:46 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Banks System & engine cover kooblekidz Airstream Motorhome Forums 1 01-04-2003 06:32 AM
