There used to be a radio and tape deck between the dash and dog house, engine cover. If it is there slide it toward the rear of the coach, disconnect the wires and remove the entire unit. Forward of the hinge is a metal panel about 8" deep held down by about ten 1/4" bolts. Remove the bolts and the entire dog house cover can be removed. If the radio unit has been removed and carpeted over you will have to pull the carpet back to reach the bolts.
There is a sticky thread at the beginning of the Classic Motorhome section that has manuals for your coach. If you have a problem I have them in pdf I can email you. Send me a PM with your email.
Cheers, Dan
~ Margaret Thatcher ~
