Old 11-29-2015, 03:21 PM   #1
2015 Interstate Ext. Coach
Manassas , Virginia
Rear Couch Question
If the couch motor fails, is there any way to raise and lower the couch? I am looking for a work-around for such a failure in the middle of a camping excursion.
curmugeon is offline   Reply With Quote
Old 11-29-2015, 09:30 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Rear Couch Question
Has your lounge seat motor failed? What are the symptoms? Could it be just a blown fuse? I don't think there is a way to move the seat without the motor, but I will admit I've never looked at for that type of failure.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-30-2015, 05:07 PM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
You can disconnect both drive shafts than you can pull it out by hand but you can only use it all in or out.
Peter
PSchw is offline   Reply With Quote
Looking for 12" tambour door above rear couch Aluminumb 1984 -1986 Excella 0 10-13-2009 10:47 PM
To couch or not to couch? Safari Tim Upholstery, Blinds, Walls & Interior Finishes 47 03-25-2009 02:51 PM
Question about switch behind couch MR AIRSTREAM 1987 - 1989 Excella 2 10-16-2005 04:23 PM
Convert Rear Queen to Couch/Bed? fangthorpe Airstream Motorhome Forums 0 10-13-2003 08:25 PM
