Old 03-24-2004, 12:14 AM   #1
Astrodokk's Avatar
Seattle , WA
Rear bumper not level
The right curb side end seems to be a tad lower than the driver side, by maybe an inch or so. There is a warble in the skin above it so one would think that end would be higher, but no. The PO said it only looked like it was lower due to the angle of the drain pipe, but if compared to the trim above the bumper, more space is seen above the right end. Since i bought it this way, I guess I'll leave it for now.
Astrodokk is offline   Reply With Quote
Old 03-24-2004, 05:27 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Astro,
the bumper is held on with 4 screws. Two on the top and two on the bottom. The bumper itself does not look bent. The frame rail ends it is mounted on are not aligned. TO straighten this out would require taking the MH to a shop that has a frame straightening machine, pulling the bumper and having them even out the rail ends. The thing that makes me wonder is that normally there is a large steel plate that spans the distance between the rails If the DR side rail is that much higher I would want to check the welds on that plate before I towed anything. The hitch is welded to that plate.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 03-24-2004, 05:40 AM   #3
LOST , Hawaii
Park it on a fairly level lot and measure from the frame rails to the ground on each side. Like Brett said, the hitch attaches there and it is a pretty solid area, but make sure the hitch hasn't been tweeked.
John
74Argosy24MH is offline   Reply With Quote
