Old 09-25-2002, 07:03 PM   #1
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
rear air suspensiom problems
my rear air bag suspension is slowly loosing air pressure ..the bags are about 18 months in service, installed by jackson center. my last trip the suspension dropped 2 inches in four hours. . was taking a couple of days, now overnight the pressure in bladders and holding tank go to zilch,, i have put the rig on a lift and sprayed soap all every thing and i got some bubbles at the control valve. worked with the valve and the bubbles stoped.. however next day the bags were at zilch again.. jackson center says bad valve. ok valve cost $202 . but i would like to convince myself that is the problem . any suggestions????????????????????????????????
al
wb13798 is offline   Reply With Quote
Old 09-25-2002, 09:26 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Al,
the price Airstream and their dealers charge for those valves is Highway robbery.
They are made by Skinner Valve and you can order them thru one of their distributors.
I got the number of my valve (i have two on my rear suspension) and special ordered it. I was quoted ~$180.- per valve from InlandRV and ended up paying 41.85 each.
http://www.parker.com/parkersql/defa...?type=2&id=119
If you stopped the bubbles at the valve and you are still loosing air, your compressor could be leaking internally. You can remedy that by installing an inline check valve right at the compressor. InlandRv sales the small check valves for $30.- something.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-26-2002, 08:42 AM   #3
wb13798's Avatar
2004 28' Classic
peter
the suspension has a check valve at the tank, to do what you suggest . dont know if it is working. i found a valve for $170 . if it is a boat or rv just plan on paying a sky high price. i pumped the suspension up last night and it is still up didnt leak down. probably is the valve as that is the one item that is subject to movement and vibrations. when it quits raining i plan to try some things to isolate the valve, and determine if the check valve is working. thanks for the suggestions.
Old 10-19-2002, 09:03 AM   #4
wb13798's Avatar
2004 28' Classic
replaced valve problem solved. but i used a $43 valve from an heavy truck supply. thanks for the help..
Old 10-20-2002, 01:19 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
question- can you deplete any air at that valve? I wondered if there was a way to let air out. My input valve is just that, and will let moisture out, and air in, but you can't let air out because of the valve further up in the system. I might have blown a bit too much air into the bags,( using air chuck). My compressor is still out...
Old 10-20-2002, 01:36 PM   #6
wb13798's Avatar
2004 28' Classic
hi
if your valve is working you can not over fill the bags. the valve is mechanical and when it raises the coach to the set height , air going into the bags is cut off. dont think the can blow the valve but who knows. pressure in the tank is normally 100lbs. you could put more but it should not matter maybe blow the hoses . dont know this is a learning experience for me . and these systems are some what the same but have various pieces of equipment to accomplish the same thing. my system has one valve some have two valves . but if you need a new valve find a parts distributor for heavy trucks . they have that valve or can get it for you. and it wont cost a arm and a leg and your first born i payed $43 for a valve airstream wants over $200. same valve.
lots of luck al
Old 10-26-2002, 01:16 PM   #7
1982 28' Airstream 280
Crowley , Texas
Send a message via Yahoo to Daddy4Bob
I am curious. I have seen a few references to, 'inflating the bags', in this and other posts. Don't your MHs have an air pump to inflate the suspension? Ours was not working when we first got it but I replaced it and all is well with the suspension. I think the springs need to be replaced though. The ship lists to the starboard side a bit on level ground.
'Can't never did nothin'!' - My Dad
Daddy4Bob is offline   Reply With Quote
Old 10-26-2002, 01:26 PM   #8
wb13798's Avatar
2004 28' Classic
hi
you have not provided enough information . it sounds like you might have two valves and one needs adjusting. if you read the replys some have one height adjusting valve and others have two valves. you need to get your self a little dirty, crawl under the coach and look at what is there . then ask ??
Old 10-26-2002, 03:45 PM   #9
Airstream Driver
1997 30' Excella
Images: 51
Daddy4Bob,
I believe all the discussions about the ride heights and the air valves was under the assumption that the on board air compressor is functioning properly.
AIR #13
Old 10-27-2002, 07:27 AM   #10
Crowley , Texas
Our coach only has one valve to inflate the suspension. I have assumed that the leaning to the right is a result of 20 years of weight and torque being applied to the springs.
Old 10-27-2002, 11:25 AM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
my compressor has not been working, although other issues with the elctrical situation, now corrected may have been the problem. I inflated the bags throught the valve at the bottom of the accumulation tank. I watched them inflate so as to not to over do it, but of course I am not sure of the pressure. The ride seems ok and the ride height judging from what others have posted is ok as well. About 32" to the mid-fender well at the rear.
Old 10-27-2002, 04:46 PM   #12
LOST , Hawaii
Daddy4Bob
Air bags come in different heights. Could be one is off a different year MH of just the closest someone could find. Does one look like it might have been replaced?
John
74Argosy24MH is offline   Reply With Quote
Old 03-01-2003, 08:58 AM   #13
NASCAR345's Avatar
control valve
Hi Guys,
I just keep finding more and more info here. It's raining so I haven't started on the battery/charging problem this morning. I have a leaking control valve on the right side. I tried to remove the linkage and it broke. I set the valve in a position that didn't leak. I was wondering a bout the truck supply part. Did it come with linkage?
Jonesy
NASCAR345 is offline   Reply With Quote
Old 03-01-2003, 09:28 AM   #14
wb13798's Avatar
2004 28' Classic
the valve comes with the metal arm that is attached to the valve. the height adjusting rod does not . if you need a valve you should have a "fleet pride" truck parts supply in your area. i have a one valve system so maybe some one with a twoer can shed some light on the problem. lol
al
Air pressure for rear air bags Jon Smith Towing, Tow Vehicles & Hitches 2 08-12-2003 09:08 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
