Old 11-16-2003, 07:03 PM   #1
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Really, Really, Really Hot
Has anyone figured out how to turn "off" the heater (engine) in their MH? I've replaced all of the heater hoses, free'd up the heater core control valve and no matter what I do with the dash control I have a lot of VERY HOT air coming from under the dash (mostly on the drivers side).
It not bad during the colder days here in the Midwest but when I'm traveling in the South I'm roasting! This was most recently an issue whe I was in Atlanta on an 80 degree day. Thought I was going to actually cook my left foot.
I read a service bulletin in the P30 manual that mentions two types of heater air boxes. One relies on the coolant control valve only to regulate the temp of the heater core and the other adds a flapper to control the source of air in the ducts (one way for heated air, the other for fresh air). I mentioned that the latter was far superior and that your could install an H shaped coolant valve in the other that would bypass coolant to the heater core altogether. I know I don't have the bypass coolant valve so I pulled the font panel (kick panel in front of the pass seat) but can't seem to figure out if I have the "better" heater box.
I'm hoping something is just stuck somewhere as I have to believe that no one would have accepted this amount of heat when the coach was new!
Looking for advice and experience. Looks like getting to the box is a big job so I'd like to have a small clue before I dive in.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-16-2003, 07:37 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
You could just install a simple on/off valve inline to keep the hot coolant out of the heater core.
Downside: running 10 degrees hotter in the already hot summer.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 11-16-2003, 07:47 PM   #3
LOST , Hawaii
Also check for air leaks around the engine cover. Seems like the heater would affect both sides.
John
74Argosy24MH is offline   Reply With Quote
Old 11-16-2003, 08:02 PM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I ended up adding a seal to the edge of the dog house and it made a big difference. I laso have a 2.5 inch hole that comes up thru the top of the doghouse and the grommet was gone. A good amount of heat came in there.
I have bypassed my heater core like peter did, due to it leaking. I will replace it some day but for now it will stay bypassed.
I also reinsulated the whole doghouse with the stuff from camping world. It really cut down on the engine noises and seems to help with the heat too. I applied 2 layers on the sides and one on the top. I can now carry on a conversation at normal voice with my co-pilot.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-16-2003, 08:10 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Bad Air Duct
The Xilver Xepelin has two 3" air ducts coming from the plenum, routed over the engine, and then through the air dam on top of the radiator on their way to the cabin air distribution system.
Both of the air ducts were chaffed when I purchased her, and one of the ducts had a significant tear in the fabric between the wire windings.
I did some bandaging on the hose with Aluminum Duct Tape, the all purpose fixer upper.
Don't know nothin' 'bout no better heater boxes, tho'.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-16-2003, 08:17 PM   #6
Airstream Driver
1997 30' Excella
Images: 51
Originally posted by thenewkid64
..... I also have a 2.5 inch hole that comes up thru the top of the doghouse and the grommet was gone. A good amount of heat came in there.
Yeah, I have that one, too. Handy for running some wires, but sure makes for a great aux heater, especially in summer driving with the heat having nowhere to go but up through that opening.
And, its located really close to the A/C air intake..brilliant!!
AIR #13
Old 11-16-2003, 08:35 PM   #7
LOST , Hawaii
Hey, I had that hole too. Finally something on mine that seems to be standard. The hole went through the plywood cover and had a base for one of those single column temporary tables. Welded a plate over the hole, seemed like a leaker to me.
John
Old 11-16-2003, 08:39 PM   #8
Airstream Driver
1997 30' Excella
Images: 51
Originally posted by 74Argosy24MH
Hey, I had that hole too. Finally something on mine that seems to be standard. ...
Sorry, John, nice try.
The 2 1/2 hole on our models is right in front of the GM fuse block on a metal housing that is actually in front of the dog house.
Not something you would find unless you remove the entertainment center.
AIR #13
Old 11-16-2003, 08:46 PM   #9
LOST , Hawaii
I knew it was too good to be true. And an entertainment center? Must have been what the table top was called in the Argosy, somewhere to deal the cards.
John
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
How hot is hot? tn2 General Motorhome Topics 10 05-21-2007 04:01 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
