Old 12-05-2002, 02:24 PM   #1
1985 32.5' Airstream 325
Dallas , Texas
Propane tank
I'm about to purchase an 80's motorhome and need to know how to recognize if the new OPD valves are installed in the propane tank. Is the
tank on Airstream motor homes aluminum? How do you weigh the amount added? Thank you in advance for answering newbie questions.
Charlie Freeman
charlief1317 is offline   Reply With Quote
Old 12-05-2002, 02:47 PM   #2
Over fill valves
The new valves are triangular in shape. The original valves were round shape. The refill stations will tell ya quick if the tanks need changing....
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 12-05-2002, 03:21 PM   #3
LOST , Hawaii
OPD should be standard as it was required on mounted tanks. The propane will be metered just as a gas pump. With the age of your MH you might have to get it recertified, but the outfits I have been to just fill without asking many questions. My tank was steel and in very bad shape. I tried to clean it up, but it was rusted so badly I replaced it.
John
74Argosy24MH is offline   Reply With Quote
Old 12-05-2002, 03:46 PM   #4
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
My 1985 345 has the OPD and the tank is in good shape. As far as I know, it is standard on all the MH's.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 12-05-2002, 03:54 PM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
OPD Picture
Found this on the rvtimes.com website:
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-05-2002, 05:04 PM   #6
Silver Bullet's Avatar
If your tanks.....
are mounted horizontally the OPD law does not effect you. Not sure if yours are but good to know, saves $ changing. Oscar
Silver Bullet is offline   Reply With Quote
Old 12-05-2002, 08:53 PM   #7
Chas's Avatar
Images: 22
OPD
Somewhat related,
I was in Arkansas a month or so ago and they will still refill the non-OPD tanks. Hear there may be more states bucking the trend.
Next time I go up I know where to get a quick buck for all my obsolete BBQ tanks laying around!
Former Airstreamer
Chas is offline   Reply With Quote
Old 12-06-2002, 07:33 AM   #8
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Exclamation OPD in Blue Beret
An article in this months Blue Beret, (WBCCI monthly magazine), talks at length about the trend of retrofitting Aluminum LP tanks with incorrect OPD's. The article tells how Airstreams account for 90% of the Aluminum LP tank population.
LP and OPD dealers do not typically stock the correct OPD for aluminum tanks. They do not sell enough of the units to justify inventory. So they have installed OPD's intended for steel tanks and this could lead to tragedy.
The OPD specifications for a steel tank are NOT the same as specs for an Aluminum tank.
If you have Aluminum tanks, make certain that you have the correct OPD before you have your tanks overfilled and have an accident that ruins your travel plans.
As far as States that still fill old tanks without OPD's, SC is one of them. It seems that it is up to the proprieter to fill or not fill. I have seen vendors that will fill and I have seen vendors that refuse to fill without OPD's.
The safest way to fill any LP tank is by weighing them while filling and not being dependant of the OPD to cut off the flow of LP into the tank.
If you have not received your monthly Blue Beret, maybe you have not joined the WBCCI. Another reason that all Airstreamers should consider joining the WBCCI.
Smily
smily is offline   Reply With Quote
Old 12-06-2002, 08:08 AM   #9
Dallas , Texas
Thanks to all who responded so promptly. It's great to have so much knowledge at hand.
Charlie
Old 12-06-2002, 08:19 AM   #10
dmreilly10000's Avatar
1953 25' Cruiser
Canton , Mississippi
Images: 14
Re: OPD in Blue Beret
Smily
What did the article say about identifying the correct valve?
I have one of my 40 lb tanks ready to go the the gas distributor right now. I didn't know that they required a special OPD valve.
dmreilly10000 is offline   Reply With Quote
Old 12-06-2002, 08:32 AM   #11
Still Working
smily's Avatar
1994 36' Classic 36
OPD in Aluminum
I do not have magazine with me at the office. Sorry.
But I believe it was a dipstick length that was the issue.
Apparently the Aluminum tanks has a recessed or upraised collar, (I am not certain which), that provides for a different depth than a steel tank. The dipstick is supposed to actuate at 80 percent fill, (shut off),
I recall from the magazine that the OPD for a 30 lb steel tank is to be used on a 20lb Aluminum tank or visa versa. I am not certain. I will post later on the specifics from the Blue Beret.
Please do not take this post as exact info at this time. I was just trying to pass the word.
Smily
Old 12-06-2002, 12:33 PM   #12
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Propane tank
RE: Blue Beret LPD Propane Valve Alert
The article that is referenced in the preceding posts is available on line at the following link:
http://www.wbcci.org/html/body_maintenance_tips.html
I don't know whether it is just my computer or the site itself, but I couldn't get the pane within the page for the maintenance tips large enough to view on-line. I printed a copy by right-clicking and selecting "print-link".
I know that obtaining these valves can be a problem. I am still waiting for the valves to arrive at my dealer for the 20 lb. Worthington tanks on my '78 Minuet.
Kevin
Kevin D. Allen
AIR #827
Old 12-06-2002, 01:03 PM   #13
1953 25' Cruiser
Images: 14
Smile Re: Propane tank
Kevin
Thanks. This really helps!!
Old 01-04-2003, 07:41 PM   #14
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
The link to the Blue Beret article was very informative. I have aluminum tanks with the built-in liquid level sensors that are connected to a panel inside the AS so I can check LP level from the comfort of the cabin. The level sensor also has a circular face gage on the tank (this is where the wires connect and go to the inside panel). I am faced with changing the valves on my aluminum tanks since the old style valves will cause a problem for refilling at some point. So I have a couple of questions.
Where can I purchase the correct OPD valves for aluminum tanks?
How do I find somebody who can install the valves and re-certify the tanks?
Thanks, Lucius
P.S. I apoligize if this is addressed somewhere else in the forum - I am still getting familiar with navigating around the various posts.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Propane Tank Emptying & Certifying drober05 LP Gas, Piping, Tanks & Regulators 1 11-03-2003 11:35 AM
Propane tank cover.... drboyd LP Gas, Piping, Tanks & Regulators 2 07-29-2003 03:42 PM
Propane Tank Cover 74SovereignInt. LP Gas, Piping, Tanks & Regulators 13 02-27-2003 10:37 AM
