Old 05-14-2013, 07:57 AM   #1
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Power problem
My TBFI 454 seems to run smooth but when I get on the gas it just does not have much power , then I let up on the gas just a little and it seems to have more power. I wonder what It is causing this. I tuned it up last month with plugs,wires, cap and rotor.
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 05-14-2013, 08:04 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Did you check the fuel filters?
Old 05-14-2013, 08:54 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Automatic transmission? If so, may need adjustment or may be low on fluid.
Cats and ultraleather Airstream upholstery don't mix!
Old 05-14-2013, 09:36 AM   #4
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I replaced the fuel filter and Dunn automatic transmission fluid to
Old 05-14-2013, 07:32 PM   #5
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I was wondering if the Fuel injection could be the problem
Old 05-15-2013, 06:17 AM   #6
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
It has done this from the first time I drove it. Especially climbing mountains ,mash the gas and not much response but let up a hair and it seems to have more power.
Old 05-15-2013, 06:29 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Exhaust restriction, bad Cat converter, "old school" quick trick, remove oxygen sensor and drive, if it's a bit noisy with more power, check for a naughty kitty.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 05-15-2013, 04:25 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also remove gas cap. If pump can't pull it will starve. If tank full of junk the tank dock "filter" may be issue. Or could be several of these choices. Also if still on distributor check vacuum advance.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-15-2013, 05:55 PM   #9
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Power problem
Mechanics chased a similar problem with my Cadillac's 8.2 Liter V8. It was an intermittent fuel delivery problem that was worsened when the motor was being stressed . . . most severe when climbing a grade with less than 1/2 tank of fuel. My usual mechanic replaced the fuel pump twice as well as all three fuel filters between tank and carburetor but the problem persisted. A mechanic (and excellent diagnostician) who specialized in repairing farm trucks offered to take a look at the problem. Within an hour he had diagnosed the problem as a clogged/collapsed fuel filter sock mounted on the fuel pick-up in the tank. Less than an hour later he had the tank drained and dropped . . . and the sock was collapsed and nearly clogged with varnish and other dirt. He replaced the filter sock and all has been well for the past six years.
I had another issue with the Cadillac many years ago that produced similar symptoms, but also caused the motor to run significantly hotter. That issue was traced to an exhaust heat riser valve rusted solid in an 85% closed position. A new exhaust heat riser valve solved the problem. That valve is now on my annual preventative maintenance check list.
I don't know whether either of these could be an issue with your motorhome's 7.4 liter, but thought that I might mention them as potential issues.
Good luck in locating your coach's gremlin!
Kevin
Kevin D. Allen
AIR #827
Old 05-15-2013, 07:31 PM   #10
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I drove this to Florida and back and ran fine. it climbed Hills just fine just slow.. it does not have vacuum advance
Old 07-09-2013, 07:21 PM   #11
Lido&Linda's Avatar
1985 34.5' Airstream 345
Chino , California
im not sure about the FI chevys but us with the caburators have a secondary electric fuel pump. mine have an on and off switch works ok off unless going uphill the fuel have a hard time getting to the carb.
The Unleaded Zeppellin
Lido&Linda is offline   Reply With Quote
Old 07-09-2013, 07:26 PM   #12
Central , Mississippi
I had a similar issue on a carbureted P30 chassis, the carbon canister vent system failed...loosening the gas cap fixed the symptoms and id'd the problem.
The tale tail was a giant "boing" about :30 seconds after shutting off the engine. It was the gas tank letting go of its vacuum induced collapsed state!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
