Old 11-29-2015, 03:43 PM   #1
2015 Interstate Ext. Coach
Manassas , Virginia
Portable Air Compresser for Interstate
Is there a best choice for a small portable air compressor for tire pressure maintenance on the MB Sprinter? I am looking at a "VIAIR 450P Automatic Function Portable Air Compressor" that has a 100% duty cycle. It sells for $240 on Amazon Prime.
curmugeon is offline   Reply With Quote
Old 11-29-2015, 04:15 PM   #2
Llando88's Avatar
2016 30' Flying Cloud
I had used this $40 one from Lowe's for about two years on my (now sold) Roadtrek Class B:
Shop Kobalt 12-Volt Power Source Air Inflator at Lowes.com
It is still working fine. I keep it in the truck now to use for my Airstream.
It works on 12V DC or 120VAC (I run it off the inverter when in the parking lot), fills way over the max psi I ran (80 psi rear) and has an auto shut off when the set psi is reached. I've found the built-in digital pressure gauge is pretty consistent with my digital gauge also. The duty cycle is 10m on, 10m off.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 11-29-2015, 04:28 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I carry a 120vAC compressor that I can power from the on-board generator (using the handy right quarter-panel exterior outlets) or from a campground's service pedestal. It puts out higher pressure and so takes less time to air up a tire than most 12v compressors I've used. Which makes a big difference when you've got seven tires to air up.
Cats and ultraleather Airstream upholstery don't mix!
Old 11-29-2015, 04:44 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I got this one from Harbor Freight. I have not filled a tire with it, but I have topped off from 65# to 75# and it did it quickly. The combination of the electrical cord and the air hose will reach the tires on my 25 from the battery on the tongue.
12Volt 150 PSI Compact Air Compressor
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-29-2015, 04:54 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
There are probably too many factors to determine a "best". I use the ViAir and am very happy with it.
Old 11-29-2015, 05:07 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yes, these are a bit pricey but are an extremely well built piece of kit as they are built for the Aussie Outback. The company also stands behind their products and will provide any parts you need to rebuild if one day that need should occur; although highly unlikely.
They can be mounted in the engine bay and have a variety of accessories to accomplish whatever you need it to do.
I have the twin cylinder 5 SCFM model running the air ride in my 310. Fairly quiet and fast. It will also run air tools.
These are NOT made in "C"
http://store.arbusa.com/Compressors-C9.aspx
Cheers
Tony
Old 11-29-2015, 09:35 PM   #7
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Mine came with a Mercedes installed portable air compressor in a compartment in the passenger step well. It also has a tire sealant to fix a flat.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-30-2015, 01:50 AM   #8
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Agree there isn't such a thing as a best tire compressor. I have the Viair 400PA-RV and it works fine, does what it should. And it turns itself off when the nozzle is closed - don't have to go back to the motor to switch it off each time.
Old 11-30-2015, 11:52 AM   #9
Richard
2006 30' Classic S/O
Merced , California
You can't beat VIAIR. Just check any off road web site and you will see VIAIR is a very popular compressor. Won't leave home without mine.
kleimanr is offline   Reply With Quote
Old 11-30-2015, 12:49 PM   #10
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I have had the same model for a couple years - has worked perfectly. I use it all the time. The hose that comes with it is plenty long enough to go from the battery box to all 4 tires on our 25' FC
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 11-30-2015, 05:15 PM   #11
2014 25' International
2010 22' Interstate
Carol Stream , Illinois
I thought most Mercedes Sprinter Airstreams came with the compressor on the passenger side.
John Millner is offline   Reply With Quote
Old 11-30-2015, 05:22 PM   #12
They do. But it's tiny, and takes bloody forever to air up a tire to 61psi.
Old 11-30-2015, 06:59 PM   #13
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Viair 440P
I just bought a Viair 440P compressor off Amazon and I am extremely pleased with my choice. I had an old Black and Decker compressor that lasted for years but wouldn't air up the rear tires on my truck to 72 lbs. for towing. This Viair takes care of it quickly as well as the 4 D rated trailer tires I keep inflated to 62 lbs.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-02-2015, 04:21 PM   #14
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Vlair RV form the win X4. I also own two cheapies and one intermediate I got from Costco. Depends on your uses. The Costco does all except run large air tools. It was about $60 the Vlair was $200+
jbxx is offline   Reply With Quote
Old 12-02-2015, 05:07 PM   #15
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Viair 400c has worked well for me.
mayco is offline   Reply With Quote
Old 12-02-2015, 09:37 PM   #16
La Center , Washington
I use the Viair compressors on all the vehicles I put air ride on. Currently on my 68 Suburban with air ride, I have a pair plumbed into two 5 gallon tanks which not only airs up my Accuair air ride, but I added a port on one tank to plug in an air hose for tires..
These work great and can handle a ton of abuse..
Find yourself a friend, and purchase them in a twin pack to get an even better deal.. Most shops that deal with air ride offer decent pricing on the dual packs..
Retired Air Force
Drewsome is offline   Reply With Quote
Portable air compressor JBinKC Tires 23 07-14-2018 04:10 PM
Re: Portable (non-RV) Air Conditioners Phoenix Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-24-2014 03:24 PM
A/C compresser will not come on kerrie Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-13-2009 07:19 AM
Portable air compresser Bing-Bing Tires 8 07-10-2007 10:11 PM
h20 compresser lubricant Flyincloud Water Heaters, Filters & Pumps 3 08-23-2004 06:25 AM
