Old 05-24-2017, 03:17 PM   #1
1979 28' Airstream Excella 28
Bay Saint Louis , Mississippi
Send a message via Skype™ to tdk51
Plumbing 79 Moho
How do you remove the shower to replace water lines to shower head on a 1979 Airstream 28 ft rear bath motor home ??? Help !!!!
tdk51 is offline   Reply With Quote
Old 05-24-2017, 04:45 PM   #2
I've not specifically worked on a 79 motorhome but based on the ones that I have worked on when Airstream assembled these things they started in the back and then worked their way forward.
That doesn't necessarily mean you have to rip everything out in front of the shower but it does mean you will have to remove something, possibly a closet wall, to get to it. It's kinda of like a jigsaw puzzle, if you enjoy those then working on your Airstream will be fun. Otherwise.....
Old 05-24-2017, 06:45 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
On my 82 280 I cut access hole under the bunk near the outside wall. The book shows the access but there was no opening in my coach. I cut the hole and covered it with a snap-in plumbing access door from Home Depot. It's not easy but I replaced my valve and re-plumbed through the hole.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-05-2017, 10:15 PM   #4
mattpalmeris's Avatar
nanaimo , British Columbia
Mine does have the access hole in the location you describe. It was cut with a 4" hole saw and covered by a square piece of vinyl covered aluminum that matches the bulkhead. It allowed me enough space to replace the value and replace the water lines with pex. 1980 28' Excella.
mattpalmeris is offline   Reply With Quote
94 Classic MoHo - Front Quarter Panel Joe Z Classic Motorhomes 2 12-16-2004 04:28 PM
MoHo Macerater Pump Installation 87MH General Motorhome Topics 7 05-14-2004 01:05 PM
Mystic Springs Moho Rally! thenewkid64 Forum Rallies & Meet Ups 44 04-25-2002 06:55 AM
