Old 06-16-2003, 07:34 AM   #1
zduke4x's Avatar
picture hanging
Need a little advice....my motorhome has many rounded areas so attaching picture frames is limited to small items....has anyone found a good fastner system where the frames can't be drilled and a clip or fastner is needed, i.e. typical art metal frames....I also realize that plexiglas is the only safe material for breakage problems...thank you, jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 06-16-2003, 07:46 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Most metal frames the backing slids out. You could fasten the backing to the wall and then slide the fame on it. Should keep it snug enough that it wouldn't slide off.
It it's the type that has the clips you turn you could put a spacer under the backing to give you just enough room to get your pinky under the frame to turn the clip.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 06-16-2003, 04:01 PM   #3
zduke4x's Avatar
spacer
You hit it right with the spacer, thanks for the idea! jem
The Silver Buffalo
WBCCI # 14067
Attaching a single picture to your post PeterH-Airstreamer Forum Admin, News and Member Account Info 62 12-04-2004 10:44 PM
Need a Picture of 70's Sovereign Couch wahoonc General Interior Topics 7 11-09-2003 07:25 PM
Classic Airstream Motorhome Picture Archive RichardT Airstream Motorhome Forums 0 11-09-2003 06:36 PM
Adding a picture to a post wallybyam Our Community 5 03-03-2003 07:29 PM
WinterStorm Picture 53flyingcloud Off Topic Forum 14 02-18-2003 04:00 PM
