Old 03-23-2004, 07:10 AM   #1
Passenger window leak '98 Landyacht
xxxxxxxxxxxxx
Bkcat is offline   Reply With Quote
Old 03-23-2004, 10:31 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Welcome to the forum!
Here's a trhead to start with : http://www.airforums.com/forum...ht=window+leak
If it does not address your specific problem, use the search button at the top of your screen to gain more insight.
Good luck!
Tom
Old 03-23-2004, 11:17 AM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Cap leak
Your landyacht Motorhome has two to three places it can leak on the passenger side near the window.
The cap, as you will see when you get on top of the unit is attached to the roof and capped with a cover. The cover will vibrate and shift as you roll down the highway. You will probably want to cover all seams with a godd coat of sealant. There are many to choose from. Kool Seal is a popular brand. But an elastomeric compound will do.
Second location is the joint that runs down the lower edge of the cap, just above the door, some good silicone for that spot.
Third spot, the window behind the passenger seat. The water can leak in there but find its way to the passenger door.
again silicone this window if its leaking.
The Motorhme is fiberglass on aluminum amd you can use silicone rather than vulkem which is recommended for the aluminum trailers. (not that you could not use Vulkem)
Congratulations on your purchase,
Smily
smily is offline   Reply With Quote
Rear passenger non moving window glass ASTailgate General Motorhome Topics 13 05-06-2014 02:00 PM
Front Passenger Slider Window Handle JudgesArgosy Argosy Motorhomes 15 01-14-2013 08:28 AM
Need passenger side window for 1994 Land Yacht 442 john Land Yacht/Legacy Motorhomes 10 10-25-2011 06:57 PM
Need 1969 front passenger window CJ of Okla Windows & Screens 4 07-03-2008 11:07 PM
