Old 12-01-2002, 04:10 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
paint or not paint
I had to fill the urge for riveting and bending aluminum this weekend, so I removed two dinged up skirt panels and installed some new ones.
Now I am in the process of repainting the entire lower section of the motorhome, but those 2 panels look so darn good in Aluminum that i am tempted to leave them like that.
Can I still come to our Motorhome rally like that or am I really crossing the line.
The wife thinks it looks real cool, kinda like there is sunken Living room.
I am just worried, Fred is going to give me a real hard time.
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 12-01-2002, 04:31 PM   #2
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Just holdin' my breath
Can't wait to see your beauty at the Vintage Get Together next month.
John W. Irwin
WBCCI #9632
Old 12-01-2002, 04:46 PM   #3
Silver Bullet's Avatar
Nice work Peter....
How did you form the roll, by hand or machine?? Oscar
Silver Bullet is offline   Reply With Quote
Old 12-01-2002, 05:14 PM   #4
Airstream Driver
1997 30' Excella
Images: 51
John I, looking forward to vintage meeting myself. Just don't inspect the front right too closely. I still have a few dings there. I keep them for memory sake.
Oscar, I used flat panels (cut-outs from my windows) and talked them into bending.
To get a straight bottom line, I used a square
3/4" aluminum stock and riveted it behind the panel. There is nothing behind it to fasten it to. It took over 100 Olympic rivets to do a little repair like that.
AIR #13
Old 12-01-2002, 07:43 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Peter- looks great to me! Makes me wonder about painting mine, I have plans to respray the greay lower panels, but wonder how aluminum paint would look? The Dupont grey is not bad but...
Old 12-01-2002, 07:56 PM   #6
Larry Brown's Avatar
walls
Its like washing the walls, minds well do the whole thing. Paint looks good and is probably is the practical answer due to rocks and road hazards but It looks cool in shiny new aluminum. Now polish the whole darn thing.
Larry Brown is offline   Reply With Quote
Old 12-02-2002, 07:25 AM   #7
LOST , Hawaii
Aluminum!!! I didn't have a lot of choice because of my caps and some of the work I did. I like my paint, but looking at your pictures aluminum is awesome, I should have held out for an Airstream.
John
74Argosy24MH is offline   Reply With Quote
Old 12-02-2002, 09:19 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Believe me Larry- the stripping and polishing thing has crossed my mind many times, however...my plasticoat is in pretty good shape, and I wonder if the shiny polished look would be too much for the campers at the KOA to handle
Even now my rig is kinda bright in the sun- you need shades to get close.
Old 12-03-2002, 06:59 PM   #9
So cool you have to ware shades
Yes we are in the same boat. mines kinda bright also .I would'nt want to cause a wreck. Ive' been stuck behing some of those big rigs with the polished rear trailer doors and I could'nt see a thing. kinda unsafe but it looks good.
Old 12-05-2002, 07:46 PM   #10
zamboni's Avatar
idea
I like the look...perhaps you could add a smaller piece to the bottom of the step so that when closed it continues the rolled aluminum edge look forward. Maybe someday do the whole thing with the Aluminum color rocker panels...you'd be one if not the only with this custom look!
zamboni is offline   Reply With Quote
Old 12-11-2002, 05:47 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
Making progress, two more doors left to strip and polish on this side. The aluminum does polish out nice. One of the panels had pretty rough sanding marks, which I wet sanded and steelwooled before polishing.
The plastic end caps will be painted.
AIR #13
Old 01-19-2003, 05:04 PM   #12
Airstream Driver
1997 30' Excella
Images: 51
Got the end caps painted, used a metalic pewder.
Now I want to paint some silver metalic flames on the rear endcaps to make a transition from the aluminum to the pewder.
The left rear was in such a poor condition that I decided to use a water base paint stripper to remove all the paint. The water base paint remover are usually not as potent as the solvent base types, which assured no damage to the plastic itself.
AIR #13
Old 01-19-2003, 09:28 PM   #13
evan's Avatar
Looks Great unpainted!
Very classy just like the big bus conversions. My AS MH has stripes and painted sections and it kind of looks rinkydink. I did notice that there is a silver painted section on the rear corner. The previous owners fixed a dent and then painted the area silver. It blends right in and you really have to look closely to see it. I think this might be a good way to go for the top panels when the clear coat goes. The roof always gets it the worst from the sun. For those considering stripping off the clear coat. The fully polished rigs I have seen look great but the upkeep is a daunting task.
evan is offline   Reply With Quote
Old 01-19-2003, 09:36 PM   #14
striker's Avatar
Images: 14
lookig sharp
i think that you should put the aluminum look on the entire body and put a nice shine to it
striker is offline   Reply With Quote
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 12:23 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 09:18 PM
Eternabond Paint to match Crsoley Kid Airstream Motorhome Forums 0 08-05-2003 07:15 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 12:56 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
