10-18-2011, 10:04 PM
1982 31' Airstream 310
Longview
P-30 Rear Suspension
I have been all over the forums looking for I parts book for My 1982 31ft. Classic Airstream rear suspension. I seen it one in a forum, but I can't find it again. I hope that soom one out there may help. I have been all over Andys store and I din't find a thing, maybe he can help me. I have been under my Airstream and it don't look good it has to have help bad. The rear suspension is springs with airbags
10-18-2011, 11:34 PM
1982 28' Airstream 280
Port Angeles
It is made by American Carrier Equipment in Fresno, Calif. They have the bushings and cross link and the bags and valve are common truck parts. I tried to copy a drawing here but the conn. in this park is terrible. You can google them for more info.
Good luck, Dan
10-19-2011, 10:38 AM
Longview
Thanks, I'll go on-line to them now!
10-19-2011, 12:47 PM
"Bess" Full Timers
Suquamish
, WA
What's the problem(s) ? Pics would help. I know waay more about that suspension than I should.
"A settled wisdom, plus the itch to be elsewhere"
10-19-2011, 12:52 PM
Redwood City
Mike, I'll remember that...I'm going to crawl under mine today!
10-19-2011, 12:58 PM
1971 18' Caravel
1974 Argosy 20
1975 Argosy 22 Rear Door
Kooskia
, Idaho
A lthough it has been a while since I had my '83, 310, I did have to learn about the air bag suspension the hard way. No one when I got it in '93 knew much about it at all, so I had to learn it by myself. In fact, I think one of the reasons I got it for a good price was that no one could figure out the air system, and they unloaded it.
Once I understood it, and got it going right, it was a great system, airtight and reliable. So, like Mike Leary, who posted above, I may also be able to help you some (from memory). Without going into details, the real problem on mine turned out to be a hidden check valve which had stuck closed.
10-19-2011, 02:55 PM
"Bess" Full Timers
Suquamish
, WA
So many possibilities of failure, does the compressor even come on?
10-19-2011, 03:26 PM
Longview
My compressor didn't come on one time,"fuse". Boy was that a hard ride!! All you good people out there have you got a name for the suspension under my 82? Or maybe a part list? Or maybe some photos
10-19-2011, 04:01 PM
"Bess" Full Timers
Suquamish
, WA
I screwed around with that mess for years to no avail, replaced the compressor, bags, still a piece of junk. Some systems work, mine never did worth a damn. Depending on where you are, a spring shop that deals with ambulances is where I'd go. Even so, the 60-40 switch could be bad and not sending information to the leveling valves, in which case, the spring shop will need a schematic for the wiring to convert the old-time switch to a newer version. I don't have the schematic, but I believe it can be gotten from AS or maybe a forum member has one. Try to pump-up the accumulator tank with aux air to see if it puts the bags to proper level (8" to 10"). You could have a leak somewhere. I don't envy anyone having this problem. After blowing a couple of grand having rookies think they'd fixed the "problems", I finally had the whole system ripped out and replaced. At the same time you do the rear, have them check the (crappy) coil springs in the front, they have a stronger spring for the P-30 now, that does not need the air bags. Have it aligned, replace the shocks, and you should be good to go. http://haldex.com
10-20-2011, 09:11 AM
Port Angeles
Come on Mike You are just frustrated because they took your money and didn't fix it.
Here is a pic of the system.
The bushings on the cross link that aligns the lower cross member can wear. I think they sell the set for about $70. The bags can be bought from Truck Spring for about $90 and the valve is about $75. My figures may be a little off because I'm old but they should be in the ballpark.
A original compressor was marginal but a new bullet proof one can be had from Viair for about $300. Start with fresh wiring from the batteries through a relay and you have a great system.
I can find you part numbers if I get some time but I think they are all posted here if you look hard enough. If you can't find them yell.
Good luck, it's really a pretty simple system and is used on trucks everywhere.
Cheers, Dan
10-20-2011, 09:18 AM
"Bess" Full Timers
Suquamish
, WA
My own damn fault; if I'd known about the forum then, things would have worked much smoother (and cheaper!).
10-20-2011, 09:37 AM
Longview
Dan,
Thanks for the photo of the susp. That the thing I been looking for, Thanks again, Lit'l Al (alfalsetto)
10-20-2011, 07:33 PM
Longview
Your photo was to hazy/blurry to see, But I got a good Photo of the susp. from American Carrier Eq. today. But I can get it on the Thread.. "Can you tell Me how to do it" Its a good copy of the susp. & air syst. & Plumbing
10-20-2011, 09:09 PM
1988 32.5' Airstream 325
calgary
, alberta
suspension
Hi to all! Just purchased a 1986 345 to add to the fleet! The rig has a few interesting problems one is the rear suspension works but on an on off switch that the po installed and it seems to me that there must be a shut off type switch or relay not working or needing replacement, Any suggestions Thanks Jonathan
| Thread Tools |
| Display Modes |
