Join Airstream Forums Today
Old 10-20-2011, 10:07 PM   #15
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Originally Posted by alfalsetto View Post
Your photo was to hazy/blurry to see, But I got a good Photo of the susp. from American Carrier Eq. today. But I can get it on the Thread.. "Can you tell Me how to do it" Its a good copy of the susp. & air syst. & Plumbing
If You have the picture on your computer hit reply to thread and scroll down and you will see a box "manage attachments". Click it and another box will appear and you can browse for the file and then upload it to your post.
I forgot where I got the pic but I am on the road so I don't have access to my files at home. If you study the pic and look closely at your suspension you can see how simple a system it really is.
Good luck, Dan
Old 10-20-2011, 10:17 PM   #16
Originally Posted by jhenry View Post
Hi to all! Just purchased a 1986 345 to add to the fleet! The rig has a few interesting problems one is the rear suspension works but on an on off switch that the po installed and it seems to me that there must be a shut off type switch or relay not working or needing replacement, Any suggestions Thanks Jonathan
I'm not sure how your 345 is set up with the tag axle but normally the compressor is controlled by a pressure switch that turns it on and off automatically at preset pressures. This would maintain a minimum air pressure in your storage tank to feed the leveling valve. A leveling valve will regulate the pressure in the air bags to keep the coach at the proper ride height. The entire system should be automatic. A dash switch would only be used to shut down the system to jack up the coach for service or tire chance or something similar.
Good Luck, Dan
Old 10-21-2011, 10:48 AM   #17
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
This is the frist time I send photos, I hope it work.
[ATTACH]Click image for larger version
Name:	Air system & Plumbing.jpg
Name:	parts explosion.jpg
alfalsetto is offline   Reply With Quote
Old 10-21-2011, 10:49 AM   #18
alfalsetto's Avatar
It worked
Old 11-01-2011, 07:15 PM   #19
cmadmaxman's Avatar
Columbia , Tennessee
My DIY
Here is a link for a DIY I did for another site. The photos do not work that I put there, and not able to fix, but all the info that I went through and part numbers are there. Good luck.
Ours works like a champ. Best thing for the compressor is to run you a big gage wire back to it with a relay. My small gage with the AS put in was getting hot, and when I went to the new system, compressor runs much faster!
When not in your Airstream,
Check out our travel site Woodexcursions-dot-com
for your vacation and business needs.
Chris & Brenda
AIR Member 12654
1982 310 Motor Home
Toad 98 Saturn SL2
More on our 310
cmadmaxman is offline   Reply With Quote
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 33 01-28-2012 09:02 PM
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 6 09-22-2011 04:46 PM
Rear window leak fixed! Really? I think so. GlobeTrottin 1964 Globetrotter 0 04-30-2011 05:42 AM
Where is rear suspension compressor relay??? 1987_345 Classic Motorhomes 9 02-21-2011 10:42 PM
