Old 03-05-2003, 09:42 AM   #1
1978 25' Tradewind
Roseland , Florida
Opening my awning
Hi,
We are finally in warm weather and would like to take down the awning. However, I can't figure out how to do it. I've had a couple of non-airstream trailers before, so am familiar with the system, but can't quite get the airstream mechanix figured out. Anyone out there with an 84 345 that can walk me through the process? I've tried manhandling, shaking and stopped short of prying. Appreciate all feedback!
Eric
kooblekidz is offline   Reply With Quote
Old 03-05-2003, 03:34 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
What brand is your awning?
Uwe
www.area63productions.com
Old 03-05-2003, 04:23 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Z-D?
Eric,
if you have the Z-D awning..check the the pin that you may have to pull at the same time to open..They're on each of the arm that extends out from each side point. This is really a two person job, IMHO.
Now, I'll assume the worse..If it's still rolled up..you may need to get ahold of the pull cord to start the open'in process.
On your main awning, it located abt the center of the length of the rolled up awning tube. Just like the ones over the window's...
Whith out further info, I can only try to picture what you're trying to ask.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-06-2003, 08:08 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Whoa!
If you have Zip Dee the roller has a lock on the right side. It is a little lever right at the end of the roller.
IF YOU FORCE THE AWNING TO UNROLL, YOU WILL BREAK THE ASSEMBLY!!!!!!!!!!
Do not arbitrarily pull the cord and never force anything.
Smily
smily is offline   Reply With Quote
Old 03-06-2003, 08:50 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
If its a carefree, Let us know and I can tell you how to unstick the roller lock. Mine was jammed and they sent me the directions.
Old 03-06-2003, 10:10 AM   #6
1984 29' Sovereign
Savannah , Missouri
Exclamation True but~
Smily,
That's true but....
The main awning has two locks, not one, on each end. (At least on mine.)
Thanks for that reminder.
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 09:09 AM
awning problems kooblekidz Airstream Motorhome Forums 2 08-30-2003 02:04 PM
Awning Repair cesurman Awnings 0 08-16-2002 11:57 AM
