Old 11-16-2014, 10:26 PM   #1
RJT
2012 Interstate Coach
Minneapolis , Minnesota
Post Onan Generator 2.5KW Microlite
Installed in Airstream Intersatate. A year ago, while under warranty, the generator died while running and powering the AC on a hot day. It restarted but would not continue running unless the starter button was continually depressed. (In that condition it does not generate electricity.) Cummins Onan fixed it but did not explain to the RV dealer the cause of the problem or what was done to fix it.
It was working fine on a recent trip until one morning when the same problem reoccurred. It started but stopped running as soon as the starter button was disengaged. Unable to obtain assistance from either the Airstream RV dealer or the Cummins Onan dealers in Knoxville we went to campgrounds with shore power. A day or two later we tested the generator. It started and it worked properly. It also worked on subsequent tests.
The only difference between the evening it worked and the next morning when it didn't was a rainfall over night.
One additional odd issue that may or many not have any relevance. I usually have the control switch for the power source set on AUTOMATIC. On one occasion while plugged into shore power the control unit indicated that it was under a HEAVY LOAD. I moved the switch to LINE POWER and the HEAVY LOAD indicator went off. Everything worked so i switched it back to AUTOMATIC and it continued to work.
RJT Minnesota
RJTennessen is offline   Reply With Quote
Old 11-16-2014, 10:30 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I am thinking the "auto" feature got fried. AS should help fix.
If a "rain" helped, I would check all electrical connections especially ground.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-17-2014, 05:19 AM   #3
Figment of My Imagination
Protagonist's Avatar
I had exactly the same problem. What had happened to me was that the generator's voltage regulator fried. Literally. My Cummins dealer showed me the scordched circuit board after they replaced it.
When you start the generator, you're spinning the starter, and sparking the spark plug, off the house batteries. But as soon as the engine starts and you release the start switch, spark is provided by the generator itself, through the voltage regulator. With the voltage regulator not working, there's no spark and the engine dies.
It's rare, but it happens.
Cats and ultraleather Airstream upholstery don't mix!
Old 11-17-2014, 05:29 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
My Onan in the B190 had a tendency to do that on really hot days - i.e., when I needed it the most - it would die for no discernible reason, then would work fine later. I always figured it was overheating or something like that.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-17-2014, 05:55 AM   #5
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
On my Allegro Bus, I had a similar problem with my 10,000 watt Onan What was discovered at Cummins Rocky Mountain near Denver was the control connection plug from generator to controls had come loose. This was cleaned, reconnected, silicone seal placed around it to help keep it tight and it never gave a problem The dealer was an exceptionally good service center and took me back into the shop to explain the issue and show me how to fix it myself if it reoccurred.
I was given such an excellent explanation such as "this is a 90% solution, replacing the plug is the 100% repair" and the charge was very reasonable.
I believe anyone in the Denver area would be well advised to seek service at this Cummins service center in Henderson. They also recommended a great restaurant.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
1980s era Onan 6.5KW MH Genset Docs Auretrvr Generators & Solar Power 4 07-07-2013 11:10 AM
Onan 6.5kw gen set III jimmied Generators & Solar Power 1 10-12-2011 09:08 AM
Onan Microlite 2500 LP problems willbrackman Generators & Solar Power 4 07-12-2011 12:01 PM
6.5kw onan generator jagcb750 Classic Motorhomes 11 04-06-2008 12:38 PM
Onan NH-RV GenSet 6.5KW jagcb750 Classic Motorhomes 25 09-10-2007 07:15 AM
