Old 06-05-2016, 11:20 AM   #1
1985 32.5' Airstream 325
Calgary , Alberta
Oil capacity 454
Hi everyone,
I have searched past posts re oil capacity but none mention oil capacity with coolers.
My problem - original dip stick was not in the engine when I bought the coach and the replacement one I found is not from a GM BB. I drained the oil,changed filter to a tall and put in 5 quarts. With the oil cooler and associated lines I am thinking maybe 6 or 7 is likely best?
I will mark dipstick levels (low and full) once I figure out.
Thoughts?
jimbro is offline   Reply With Quote
Old 06-05-2016, 03:07 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by jimbro View Post
Hi everyone,
Thoughts?
Measure what you took out including draining the filter and you should be safe if engine was showing normal oil pressure before the change except you changed to tall filter then either add a quart more or fill the filter before installing.I have found add on oil coolers on my 454 and it would be hard to include them as from there location I doubt that they drain when the oil is changed.
Old 06-05-2016, 03:36 PM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
The 454 in my '97 one ton Chevy van holds 7 quarts.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-06-2016, 02:45 AM   #4
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
7 quarts sounds right to me. It's all contained in the Motorhome chassis guide and service manual in the links on the parts thread I created a few weeks ago. You've also got the synthetic, sae30, 10w-40 debate to contend with. You'll find more detail on that in the service manual.
Boom Sounds is offline   Reply With Quote
Old 06-06-2016, 11:34 AM   #5
Lubricants
Name:	ImageUploadedByAirstream Forums1465234448.998695.jpg
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
454 oil pan capacity? Astrodokk Mechanics Corner - Engines, Transmission & More... 6 08-29-2009 02:14 PM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
345 oil capacity swinginping Airstream Motorhome Forums 8 08-23-2008 12:38 PM
Kohler generator oil capacity? geo-357 Generators & Solar Power 2 07-09-2004 10:49 AM
