Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Prev Previous Post   Next Post Next
Old 07-15-2002, 03:11 PM   #1
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
oil and trans fluids
I checked my trans fluid after my recent looong trip and it was down quite a bit. With the extreme hot weather and all I am not surprised, but wondered what usage you other motorhome folks were seeing.
Oil- I use a quart every 1000 or so, used 2 1/2 on the 2000 mile trip.
Trans- This was the first time I needed more than a pint. Used a quart plus.
By the way I am using Valvoline Max oil and trans fluid- might be good for the seals and such. Recommended for older engines and transmissions.
Also another note- while looking around the net I went to the WIX Filters site where I found they have filter numbers listed for ONAN generators. I put in my series and pulled up the application for oil and air. Might be a less expensive alternative to the factory filter which is a bit pricey.
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 09:22 PM
Auto trans temps chart FrankR Mechanics Corner - Engines, Transmission & More... 9 05-05-2002 09:42 AM
