Old 05-23-2014, 04:48 PM   #15
1997 31' Land Yacht
Mahone Bay , Nova Scotia
Don't know what happened there, that reply was supposed to go to Johnsito.
wheelygoode is offline   Reply With Quote
Old 05-23-2014, 11:03 PM   #16
Trident's Avatar
1998 30' Cutter Bus (Chevy)
Everson , Washington
Originally Posted by wheelygoode View Post
Hi - we also have a 1997, and we copied Trident's idea. For power we took power from the plug under the dinette seat and made a second plug in the closet, drilled a hole for the wire behind the TV.
Just a word of caution "outlet in the closet" not good. If you can be sure clothes, paper bags, blankets and other combustibles will never be placed on or around the plug your good. I just don't want to be reading about you in the news paper. 12 volt ok in the closet 120 volts not.
Did you use the drawer slides for your TV mount?
Trident is offline   Reply With Quote
Old 05-29-2014, 09:09 AM   #17
Johnsito's Avatar
1997 31' Land Yacht
Not sure about the antenna rewiring. I'll investigate.
Johnsito is offline   Reply With Quote
Old 05-29-2014, 06:45 PM   #18
1997 31' Land Yacht
Sorry, I thought I had replied to your post - I don't want to read about us either! We put the plug at the extreme front of the closet ( no clothes or anything else there), but to be sure, we will look into a shield for the plug. Thanks for the warning!
Old 05-29-2014, 06:48 PM   #19
1997 31' Land Yacht
Oops I forgot to answer your question. We didn't use the drawer slides but settled for a regular wall mount because we had it already. But your idea is very clever, and if we find we need to access the back of the TV, we may switch.
Old 06-06-2014, 02:51 PM   #20
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
How about building a cabinet to go in the big hole.
92landyacht is offline   Reply With Quote
Old 06-13-2014, 11:39 PM   #21
Trident's Avatar
Well this is what I came up with, not to bad. I have about $ 5.00 in it and lots of hours. There is something behind the panel so it's not wasted space. I was thinking making the ships wheel turn with the steering wheel but that may be over doing the theme, just kidding.Click image for larger version
Name:	ImageUploadedByAirstream Forums1402724238.198892.jpg
Old 06-14-2014, 12:24 AM   #22
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
My newer moho had a 22" tv mounted in the same place, but I wanted to go HD and larger. There is AC and cable in the cabinet above so I ran everything form there, used a Costco swivel mount but kept the back plate that has a Velcro strap for travel. I remounted the swivel with the back plate, new Velcro and have a wireless UVerse box to use when I am docked next to my house. The 26" is the maximum fit when up against the wall without sticking out.
I had to add some cushioning (cork gasket in this case) at some points of the mount because the metal-to-metal was grinding away when driving.
The mount pulls out and swivels, and there is an upgraded audio since we susually watch a movie or other dvd.
ID:	214189   Click image for larger version
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
one problem solved..now need to find new burner! JohnGalt48 Water Heaters, Filters & Pumps 8 06-24-2007 02:48 PM
New Member currently looking is now an owner hapitauk Member Introductions 7 01-02-2007 01:31 PM
Dull bathroom fixtures now shiny new. Waynon General Interior Topics 4 09-09-2006 07:52 AM
New and now more informed... garthbf Member Introductions 4 08-11-2006 08:40 AM
Installing new water heater now! HELP rochsmama Water Heaters, Filters & Pumps 27 05-19-2005 07:57 AM
