Old 10-09-2016, 02:35 PM   #1
2017 Interstate Lounge Ext
Parker , Colorado
New 2017 Interstate problem/question on Fusion
Apologies in advance for the lamest question ever to hit a forum. It is lame because we cannot even figure out something as simple as the infotainment off switch!
Just bought a lovely 2017 Interstate Lounge with the Fusion system. The power switch does not seem to function to turn off the system with the key in running the engine or with it out and plugged in with a shoreline. Is this by design or an issue? We were plugged in and packing for our first trip when we noticed that the Fusion video display was on. We figured out that we could turn the screen off by swiping down to find the command to turn the screen off. The only way to get the radio to turn off was to put the source on something that was not active.
Any help or comment will be very appreciated.
Con-Fusion in Colorado
ToRoark is offline   Reply With Quote
Old 10-09-2016, 02:50 PM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I don't have an Interstate, but have had four AS, now a 2017 Classic. If dealer can't help you call Jackson Center their customer service group will help and are a great group of folks.
Bud
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 10-09-2016, 04:32 PM   #3
Parker , Colorado
Thanks.
Colorado dealers are closed on Sunday's unfortunately. Thanks for the recommendation on the Jackson center.
Old 10-09-2016, 05:26 PM   #4
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Not sure about you new Interstate and the fusion. Usually if the main house power switch is on your radio is powered from the house batterie and will not shut down with the ignition key. You have to turn it off manual.
PSchw is offline   Reply With Quote
Old 10-09-2016, 08:28 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Did you get an owner's manual for the Fusion system? Best I can determine it is the Fusion RV-IN801. The manual can be downloaded from this link.
https://fusionentertainment.com/life...units/rv-in801
In reading the manual it indicated the power on/off switch is the touch symbol in upper right hand corner of the display. Attached picture has red arrow pointing to this switch.
If that switch doesn't work you need to check with your dealer as there may be a problem with your unit. I noticed on the Fusion web page that they have just released a software update last month.
Hope this helps,
- - Mike
Name:	Fusion RV-IN801edit.JPG
Old 10-10-2016, 08:05 AM   #6
Parker , Colorado
Thanks.
Unfortunately, that is the button that is not operational. Thanks so much for your time posting this and I will download the manual. We got a quick start guide for the system and a few photographed pages.
Old 10-10-2016, 12:44 PM   #7
2017 Interstate Grand Tour Ext
Bozeman , Montana
Hold the power button down for about 10 seconds to completely turn the unit off. (Unless the unit is defective and the button not functioning).
ArcherTC is offline   Reply With Quote
Old 10-10-2016, 02:02 PM   #8
mrgolf's Avatar
Charleston , South Carolina
We too had the same question after the Fusion remained on. Holding the button down for an extended period does turn it off.
One other FYI for you. I signed up for the SiriusXM service and wondered why Fusion fails to show the name or logo of each station preset as most/all other advanced systems do. The presets only show a station number. Difficult for most people to know what each station is by number. I exchanged notes with a very helpful Fusion rep and he indicated this is a future enhancement the team is now aware is needed and will be considered.
mrgolf is offline   Reply With Quote
Old 10-11-2016, 12:37 PM   #9
St. Pete Beach , Florida
We have the same situation. - with a twist. If we're finally able to get the system turned off, it will turn itself back on within a few hours! Anyway, we've been told by our dealer, Tampa RV, it needs a software update that is not released yet. If anyone has more or differing information, please clue me in. It's more than a little startling when driving in silence at night to hear the radio suddenly blast in. Oh. Another thing: because it most likely has been unknowingly ON in my driveway, it has run down the battery
Perpich is offline   Reply With Quote
Old 11-26-2016, 07:34 AM   #10
Gallatin Gateway , Montana
Have a 2017 AI Touring and am still learning about the Fusion. Overall, seems like a great unit but a couple of things I've learned by digging thru the 'skinny' user guide and/or punching screen selections.
1) To turn the unit off, push and hold the Power icon for about 10 seconds (I did notice, however, that when I crank the AI the Fusion automatically turns itself on),
2) Make sure the software is the latest version - ver 2.8 as of this moment; if not, follow the update instructions in the manual,
3) For sure, if you have a SmartPhone, download the Connect + app and install it - you can use your iPhone/Android to control the radio (and run selected iPhone/Android apps); seems to work great but takes a little experimenting to get the right sequence of Bluetooth connection steps; once connected, it's performs well
bob323 is offline   Reply With Quote
Old 11-26-2016, 05:01 PM   #11
Fulton , Maryland
Originally Posted by bob323 View Post
Have a 2017 AI Touring and am still learning about the Fusion. ......
I looked at the 2017 wiring diagram and noticed Airstream wired an ignition signal to the radio. Guess the logic of the Fusion is to turn on when ignition voltage is present.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 12:46 PM
2017 Interstate w/ Fusion infotainment system - update to v2.8 FlyFishinRVr Sprinter and B-van Forum 19 02-28-2017 03:46 PM
Fusion for Plastic 76sovereign Sinks, Showers & Toilets 11 09-05-2008 01:15 PM
Krylon "fusion" stuart1 Plumbing - Systems & Fixtures 2 06-24-2003 08:36 PM
